Calculate Molar Specific Heat | Q=m*Cp*(change in temperature)
  • Thread starter Thread starter ecthelion4
    Mass Specific
To calculate the molar specific heat (Cp) using the equation Q=m*Cp*(change in temperature), first determine the heat capacity per mass. Then, convert this value to heat capacity per mole by multiplying it by the molar mass of the substance. Alternatively, you can calculate the number of moles from the given mass and use that to solve for Cp directly. Both methods will yield the molar specific heat needed for the problem. Understanding these conversions is crucial for accurate calculations in thermodynamics.
ecthelion4
From Q=m*Cp*(change in temperature), they give me all but Cp, which I calculate, and they also give me a mass per mole of the substance. Now the next part of the problem asks for the molar specific heat of the substance, but the equation for this eludes me.
So you've calculated the heat capacity per mass? Convert your heat capacity per mass into heat capacity per mol. Look at the units to see. You will just multiply your answer by the molar mass.
Or, do the calculation again, this time convert the mass given into moles
#moles = (mass in grams) / (molar mass in grams per mole)
and solve for Cp.
Either way.
