Speed and Direction of Electron orbiting within a Solenoid
The discussion revolves around calculating the speed and direction of an electron orbiting within a solenoid, where the electron's orbital diameter is 3.0 cm and the solenoid's diameter is 4 cm. Participants express uncertainty about how to approach the problem, questioning whether to use conservation of energy or to first determine the magnetic field (B field) of the solenoid. The relevant equations for the radius and period of the electron's motion are provided, along with a formula for the B field of the solenoid. There is a request for additional information, such as the current in the solenoid or answer choices, indicating that this may be a multiple-choice question. The discussion highlights the need for clarity on the problem's parameters to proceed with the calculations.
rodanme
In Fig. 28.8, a view of the solenoid, showing the clockwise sense of the current in the windings, is given. An electron is in circular motion near the center of the solenoid, with an orbital diameter of 3.0 cm. The speed of the electron and the sense of the orbital motion are closest to
The diameter of the solenoid is 4 cm
The diameter of the e- orbiting within the solenoid is 3 cm
r = mv/qb
T= (2*pi*m)/qb
Not really sure how to start the problem.
Would I take a conservation of energy approach?
Do I need to try and figure out the B field of the solenoid?
Start with finding the B field of the solenoid.
For the next step, consider that the electron is a charged particle that travels in that B field.
The Equation for B_solenoid = Mu_0 * I * n
how can I find the current of the solenoid?
They have to give the current, or they want the answer in terms of the current.
Judging by the problem statement, this looks like an MCQ problem. If so, do you have the answer list?
If not, do you have this figure 28.8?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
25K
