Speed of sound related to absolute temperature
The speed of sound is directly related to the square root of absolute temperature, allowing for calculations using the formula √T. The multiplier, k, is not essential for determining the velocity of sound. Users can scale the velocity by the ratio of the square roots of the initial and final temperatures. Despite attempts to apply this method, one user reported obtaining the same value again. The discussion emphasizes the importance of understanding the relationship between sound speed and temperature for future problems.
Bolter
See image attached below
v = k * sqrt(T)
Here is the Q
Very unsure about how to approach this question but this is what I have tried
Any help would be really appreciated! Thanks
Your calculation of the multiplier, k, is not really necessary. The velocity of sound will change in proportion to ##\sqrt T ##, so you can scale velocity by ##\sqrt {T_1} / \sqrt {T_0} ## without even knowing what k is.
Likes Bolter and berkeman
Thank you, I have tried this and get the same value again. I'll keep a note of using next time I get a similar problem :)
Likes berkeman and FactChecker
