Speed of Water Coming out of Vertical Cylinder
The problem involves a vertical cylinder containing water, with a specific focus on calculating the force required to prevent movement when a valve is opened. The cylinder has defined dimensions and water height, but lacks explicit pressure values, complicating the application of Bernoulli's equation.
  • Participants discuss the implications of the water height and outlet position on pressure calculations. There are inquiries about how to determine liquid pressure at a certain depth and the relevance of the term 'head' in fluid statics. Some suggest using Torricelli's Law as an alternative to Bernoulli's equation.
The discussion is ongoing, with participants exploring different approaches to the problem. Some guidance has been offered regarding the assumptions about atmospheric pressure at the top of the cylinder and the potential use of Torricelli's Law to derive necessary calculations.
Participants note the absence of pressure values and the challenge of applying certain equations due to the flow of liquid, which may affect the interpretation of static pressure conditions.
slasakai
A vertical cylinder with diameter 9 cm has an outlet on its side with diameter 3cm, water is filled to height 50cm and the outlet is 5 cm above the bottom of the cylinder. the outlet is closed by a valve, calculate the force required to stop the cylinder from moving when the valve is opened.
A1V1=A2V2
Bernoulli's Equation [too long to type!]
I'm struggling as no pressures are provided, and applying Bernoulli's equation isn't straightforward. I'm not sure whether it's possible to interpret it as the fact that the top of the cylinder is open, as this would make the problem simpler. I would really appreciate some insight to this question :)
thanks in advance
How do you find pressure of a liquid at a given depth? (or rather, when the surface of the water is a certain height above where you're desired measurement point)
You have water in the cylinder. You are given the height of the water above the bottom of the cylinder and the height of the outlet above the bottom as well. Water is affected by gravity. You can determine the pressure of the water by a few simple calculations. Do you know what the term 'head' means in fluid statics?
Rather than using Bernoulli's equation, how about Toricelli's Law:
http://en.wikipedia.org/wiki/Torricelli's_law
not sure how, as the pressure at the top of the cylinder is not given and the you can't use the equation P=P0+ρgh as the liquid is flowing
To get this cart moving, assume that the top of the cylinder is vented to atmosphere.
ok, so using Toricelli's Law you can get mass flow rate, and therefore the momentum of the water coming out of the valve, and therefore the force needed to keep it still. Thank you for your help!
  • · Replies 21 ·
