Calculate Spring Constant and Force for Compression
To calculate the spring constant, use the formula for elastic potential energy, E = (1/2)kx², where E is 25J and x is 0.075m. Rearranging the equation allows for the determination of the spring constant k. For the force required to compress the spring, apply Hooke's Law, F = kx, using the spring constant obtained in the first part. This approach provides a clear method to find both the spring constant and the force for compression. Understanding these calculations is essential for applications involving springs in physics.
NewJersey
A spring constant stores 25J of energy when compressed by 7.5cm
a) Find the spring constant
b) Find the force to compress the distance
For part (a), you'll need to know the equations to find the spring constant based off of the energy [E] that is exerted to move it the distance [x] it moves, which is also equal to its amplitude [A].
For (b), the force exerted can be found by using the spring constant value you found in (a) and muliplying it by the distance it is compressed.
F_{x} = - kx
