What is the equation for a spring launcher?
  • Thread starter Thread starter Riman643
    Launcher Spring
The discussion centers on finding the correct equation for a spring launcher, specifically how to incorporate the angle of launch. The user initially presents an equation for potential energy but struggles with its accuracy and the inclusion of launch angle. They propose a revised equation relating spring potential energy to gravitational work and kinetic energy. Feedback indicates that their latest attempt appears correct. The conversation highlights the need for clarity in applying physics principles to solve the problem.
Riman643
What is the generalized equation of the initial launch speed for a spring launcher at different angles? Use PE of the spring, mass, and angle in the equation.
Ei = Ef
PEspring = 1/2 kx^2
KE = 1/2 mv^2
I am really stuck and confused. I just need the equation. Thanks!
Here is my attempt at solving:
PEspring = 1/2m(Vx^2 +Vy^2)
Riman643 said:
Problem Statement: What is the generalized equation of the initial launch speed for a spring launcher at different angles? Use PE of the spring, mass, and angle in the equation.
Relevant Equations: Ei = Ef
PEspring = 1/2 kx^2
KE = 1/2 mv^2
What have is your assessment so far?
This is my attempt
PEspring = 1/2m(Vx^2 +Vy^2). I know this is not right. I am confused and have been trying to figure this out for two days now. I do not know how to incorporate the angle of the launcher.
So here is my next attempt
PEspring = Wgrav + KE
(1/2)kx^2 = mgsin(theta)x + (1/2)mv^2
Is this correct?
Is this correct?
Looks right.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
