Spring Problem- Unknown mass and constant
To solve for the spring constant without knowing the mass, additional information is typically needed, such as the force applied or the displacement of the spring. The equation F = kx relates the force exerted by the spring to its displacement, but without mass, it is challenging to determine the spring constant directly. Clarification on whether there are other parameters or conditions provided in the problem is essential for a complete solution. The discussion highlights the need for more context to proceed with the calculations effectively. Understanding the relationship between force, mass, and acceleration is crucial in solving spring-related problems.
C_Conrad8
x= .6096 m
F=ma [m- unknown] [a= 9.81 m/s]
F= kx
No idea..
Basically, you are in a cannon. It has a spring.
The only thing I really want to know- how do you solve for the constant when you don't know the mass?
Is that all you are given or is there more of the question?
