Maximizing Spring Elongation in Charged Object System
  • Thread starter Thread starter Tanya Sharma
    Charged Spring
The discussion revolves around calculating the maximum compression and elongation of a spring system involving two charged objects in an electric field. Participants explore the equations of motion and potential energy considerations, emphasizing the importance of the spring's natural length and the forces acting on the charges. There is a debate about whether to neglect the Coulomb force between the charges, with some suggesting that it should be approximated rather than ignored. Ultimately, the maximum elongation is derived as 2qE/k, while the minimum elongation is confirmed to be zero, indicating no compression occurs. The conversation highlights the use of energy conservation principles and differential equations in solving the problem.
Tanya Sharma
Two equal and opposite charged objects of magnitude 2C and mass 2kg are attached to a spring of spring constant 4 N/m in the natural length of the spring. The system is suddenly placed in a uniform electric field of field strength 5 N/C in the direction of electric field such that the -ve charge is towards the origin of electric field. assuming the natural length of the spring to be large, find the maximum compression and elongation in the spring length.
First I tried to find the maximum extension.
Let charge -2 C be at a distance x1 and charge +2 be at a distance x2 from the origin .
Let the length of the spring be l .
The length of the spring at any instant is x2-x1 .
The extension in the spring would be x2-x1-l .
The force of attraction between the charges would be kq2/(x2-x1)2 i.e 16/(x2-x1)2
Force due to the external electric field will be of magnitude 10N .
EOM for mass 1 (i.e -2C ) will be k(x2-x1-l)-10+16/(x2-x1)2 = 2d2x1/dt2
EOM for mass 2 (i.e +2C ) will be 10-k(x2-x1-l)-16/(x2-x1)2 = 2d2x2/dt2
From the above we get ,
2(d2x2/dt2-d2x1/dt2)=20-2k(x2-x1-l)-32/(x2-x1)2
or , d2x2/dt2-d2x1/dt2=10-k(x2-x1-l)-16/(x2-x1)2
d2(x2-x1)/dt2=10-k(x2-x1-l)-16/(x2-x1)2
Now putting x2-x1 = z ,
We have d2z/dt2=10-k(z-l)-16/z2 .Now I need to maximize z .
Is it the correct way to approach the problem ?
I would be grateful if someone could help me with the problem .
Hello Tanya!
I am not sure but I think you are required to use the assumption that the natural length of spring is large to cancel one of the factors.
Also, how do you get kq^2=20?
For this kind of problems (two interacting bodies) it is usually simplest to convert to the CoM frame and use conservation of total momentum in the CoM frame. This separates coordinates into the coordinates of the CoM and the distance between the bodies.
Does that mean the force between the charges doesn't come in picture ? Do I have to neglect this force ?
I have fixed the error .kq2=16
Have I approached it correctly ?
This is what I think but as I said, I am not sure. :)
Still incorrect. It looks to me as if you are confusing the Coulomb's constant with the spring constant.
:redface: . Forgive me for that .What next ?
You can use the substitution ##x_2-x_1-l=z## but your substitution is fine too.
What do you get if you solve the differential equation? I suggest to denote everything by symbols and substitute the values later.
Btw, voko's method is a nice one, you can use energy conservation in the CM frame, no need of differential equations. :)
Work Energy theorem is the best approach according to me.
Since the magnitude of charge and the masses are same, these objects will move symmetrically in opposite directions. Therefore, when maximum compression and elongation occur, both the objects will be at rest. So you just have to consider
(i)Spring potential energy
(ii)Interaction potential energy
(iii)Work done by external force
while making the equations.
I understand work energy approach is better .But since I started off with DE's ,want to finish it first.
The DE is
or , d2z/dt2+kz-(kl+10) = 0The solution is z = C1cos(√kt) + C2sin(√kt) + (l + 10/k)
Does that make sense ?
"assuming the natural length of the spring to be large" means that you are supposed to approach the problem assuming that ## s = z - l << l ##. It does not mean that the term for the electrical interaction between the charges is completely neglected. It means that it must be approximated with a term linear in ##s##.
Hi voko...
Suppose we neglect the force between the charges , does post #9 makes sense ?
In the sense whether the solution of the equation in #9 is correct, yes.
Okay...
So ,z = C1cos(√kt) + C2sin(√kt) + (l + 10/k)
Now ,using z(0) = l we get C1 = -10/k .
How do I find C2 ?
What about ##\dot z(0)##?
That gives C2 = 0 .
So,z =(-10/k)cos(√kt) + (l+10/k) . Is it correct ?
The equation from #9, which you have solved, is not a correct equation for the original problem. Yet you used the initial conditions from the original problem to determine the coefficients in its solution. That does not look correct to me.
Hi voko! :smile:
This is the DE we have:
$$-2k(x_2-x_1-l)-\frac{2Kq^2}{(x_2-x_1)^2}+2qE=m\left(\frac{d^2x_2}{dt^2}-\frac{d^2x_1}{dt^2}\right)$$
If we go with Tanya's substitution ##x_2-x_1=z##, I don't see how we get z-l in the denominator of electric force. :confused:
I suggest that you first rewrite that equation in terms of ##s##. Then think how you can simplify the equation if ##s \ll l##.
OK, so I switch to the substitution ##x_2-x_1-l=s##, then I have ##\ddot{x_2}-\ddot{x_1}=\ddot{s}##, hence
$$-2ks-\frac{2Kq^2}{(s+l)^2}+2qE=m\frac{d^2s}{dt^2}$$
$$\Rightarrow -2ks-\frac{2Kq^2}{l^2}\left(1+\frac{s}{l}\right)^{-2}+2qE=m\frac{d^2s}{dt^2}$$
$$\Rightarrow m\frac{d^2s}{dt^2}=-2ks+\frac{4Kq^2s}{l^3}+2qE-\frac{2Kq^2}{l^2}$$
Do I have to solve the above DE?
The problem does not want you to solve differential equations. It wants you to find the minimum and maximum elongations.
Note that the equation you obtained can be re-interpreted as an equation for a massive particle in a force field, where the force depends linearly on the position. That force is potential, so you could find the corresponding potential energy. Then you can write down the equation for conservation of energy, and determine the min/max elongation from it.
But still, I would like to know if the DE is correct.
Okay, I try the conservation of energy. The acceleration of COM is zero. I switch to COM frame and use conservation of energy. Initially, let both the masses move away from each other, then
$$\frac{-Kq^2}{l}=qE(x_1+x_2)+\frac{1}{2}k(x_1+x_2)^2+\frac{-Kq^2}{(l+x_1+x_2)}$$
where ##x_1## and ##x_2## are the distances moved by A and B. Also, at max elongation, kinetic energy of blocks is zero. Let ##x_1+x_2=s##, then
$$\Rightarrow Kq^2\left(\frac{1}{l+s}-\frac{1}{l}\right)=qEs+\frac{1}{2}ks^2$$
$$\Rightarrow -\frac{Kq^2}{l^2}\left(1-\frac{s}{l}\right)=qE+\frac{1}{2}ks$$
Is the above correct?
Yes, it was correct. I did not mean that you should drop that equation. Rather, I meant that you could use that equation to restore the potential energy for the fictitious massive particle. The equation was ## m \ddot s = F(s) ##, so find ##U(s)## such that ## F(s) = - U'(s) ##, then use conservation of energy.
I do not follow you here. The LHS is apparently the initial potential energy of electric interaction of the charges. What the about the initial potential energy of the interaction with the field?
I am having difficulty understanding the RHS. It seems that ##x_1## and ##x_2## are measured from the CoM, but they use different sign conventions. Is that correct? Secondly, the RHS must have terms for kinetic energy in general.
But, again, I did not mean that you should drop the DE and redo everything from scratch.
Sorry for so many errors voko. :redface:
I asked Tanya for the answer to the given problem and the given answer is ##2qE/k##. If we neglect the attractive Coulomb force, this answer is easily reached. Is there an error in the question?
I have to leave now, I will make a correction post when I return. Thank you for all the help voko! :smile:
Well, if that is the answer, then the problem was already solved.
I would not say there is an error in the question, but it is definitely ambiguous. It should have said "ignore the interaction between the charges".
Thanks voko! :)
So we have the following DE:
$$-2ks+2qE=m\frac{d^2s}{dt^2}$$
The solution of the above differential equation is:
$$s(t)=\frac{qE}{k}+A\sin(\omega t)+B\cos(\omega t)$$
where ##\omega=\sqrt{2k/m}##.
Using the initial conditions,
$$s(t)=\frac{qE}{k}(1-\cos(\omega t) )$$
The question asks the maximum compression and maximum elongation. Maximum elongation is maximum of ##s(t)## i.e ##2qE/k##, how to find the maximum compression? :confused:
Minimum elongation does not mean there will be any compression. From the final formula for ##s##, it is obvious that the minimum elongation is zero.
That could also have been understood from conservation of energy. Initially, kinetic energy was zero, so potential energy must have been at a maximum, thus the initial state must correspond to either min or max elongation.
I too thought that the minimum elongation should be zero as seen from the equation but I just wanted to be sure. Thanks a lot for clearing it up voko! :smile:
