What Mass Must Be Hung to Produce Specific Standing Wave Loops?
To determine the mass required to produce specific standing wave loops on a string with a linear density of 6.6*10^-4 kg/m and a frequency of 120 Hz, the velocity of the wave is calculated using the formula v = Γf. The calculations show that for one loop, a mass of approximately 8.73 kg is needed, while for two loops, the required mass is about 2.18 kg, and for five loops, it is around 0.155 kg. The discussion highlights the need to adjust the harmonic number in the calculations for different loop configurations. The final values align with the expected outcomes for each harmonic scenario.
gmmstr827
One end of a horizontal string of linear density 6.6*10^-4 kg/m is attached to a small amplitude mechanical 120-Hz oscillator. The string passes over a pulley a distance of l=1.50 m away, and weights are hung from this end. What mass m must be hung from this end of the string to produce (a) one loop, (b) two loops, and (c) five loops of a standing wave? Assume the string at the oscillator is a node, which is nearly true.
µ = Γ = 6.6 * 10^-4 kg/m
f = 120 Hz
L = 1.50 m
g = 9.8 m/s^2
F_t = mg
v = √(F_t*L/m)
v = Γf
Γ = 2L/n where n = 1 for first harmonic, n = 2 for second harmonic, etc.
I'm really not sure where to go with this one, so I'm just going to solve for what I can.
First, I'll solve for velocity.
v = Γf = (0.00066 kg/m)(120 Hz) = 0.0792 m/s
Now I'm going to set the velocity formulas equal to each other to try to solve for m.
√(F_t*L/m) = Γf
√(mg*L/m) = 0.0792
√(g*L) = 0.0792
√(9.8*1.5) = 0.0792
Oh wait, mass canceled itself out >.<
Help is much appreciated!
Thank you!
Likes zay47olali
Here
v = (Mg*L/m)^1/2, where M is mass hung from the other end of the string, and m is the mass of the string.
rl.bhat said:
Here
Okay, so I would plug everything in and solve for M?
0.0792 = (9.8M*1.5/0.00066)^1/2
M = 2.82 * 10^-7 = 0.000000282 kg
This seems like a very small mass. Is this how it's solved?
Check your v value.
Do I use µ = m/L >>> µL=m where µ = 6.6*10^-4 kg/m and L = 1.50 m
so the mass of the string = 0.00099 kg
then
Γ = 2L/n where n=1 and L = 1.50 m so
Γ = 3
So 3*120 = 360 m/s
v = √(Mg*L/m)
360 = √(M*9.8*1.5/(9.9 * 10^-4))
m = 8.73 kg?
So for part b, I would just use 2 instead of 1 for n; and part c I would use 5. Yes?
b) v = 180 m/s; m = 2.18 kg
c) v = 48 m/s; m = 0.155 kg
Seems good.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
