Stanford: objects in spacetime all move at constant speed c?
In summary, the conversation discusses how objects in spacetime all move at constant speed c, but their spatial and temporal speeds may change depending on their direction and velocity. This concept can be better understood through mathematical equations and is not equivalent to moving at speed c through space. However, the velocity of light is still c through spacetime.
AstroMath
24
In this http://web.stanford.edu/~oas/SI/SRGR/notes/SRGRLect6_2007.pdf, it is stated:
Likewise, objects in spacetime all move at constant speed c in spacetime but if you change its direction, say by moving at speed v in the x direction, then spatial speed will change and so will the speed along the ct direction. Again, its total speed will still be c through spacetime.
Brian Green of Columbia University also says the same thing, as do many others.
Are they right?​
Yes they are right, but it doesn't mean what it sounds like it means. In particular it means nothing like the same as moving at speed c through space, which only massless particles like photons can do.
In cases like this, the only exact presentation of the science is a mathematical one, which involve be saying something such as that the four-velocity vector of a massive particle has magnitude c (or magnitude 1, if we're using relativistic units). The linked pdf starts to talk about that around the bottom of p2.
What do you mean by this, "Yes they are right, but it doesn't mean what it sounds like it means. In particular it means nothing like the same as moving at speed c through space, which only massless particles like photons can do."?
They're not talking about space like you are.
They are talking about spacetime.
Please do not confuse your space with their spacetime.
The statement that all objects move at speed c through spacetime is equivalent to saying: Every second, you move one second into the future. It's true, but it's not that profound of a statement.
A more correct statement would be:
Massive objects in spacetime all move at constant speed c in spacetime (i.e., is a vector with magnitude c) [and spatial speed v (also called ##\tanh\theta## [a slope]) in space]
but if you change its direction, say by moving at nonzero spatial speed v in the x direction,
then spatial component (##\gamma\ v## or ##c\sinh\theta##) will change and so will the temporal component (##\gamma\ c## or ##c\cosh\theta##).
Again, its total speed (##\sqrt{(\gamma\ c)^2- (\gamma\ v)^2}##) will still be c through spacetime.
Massless objects in spacetime all move at constant speed zero in spacetime [and spatial speed c in space].
So the velocity of light through spacetime is 0? I would argue that the velocity of light is c.
Here is the math:
##\left(\dfrac{ds}{d\tau}\right)^2=\left(\dfrac{c \, dt}{d\tau}\right)^2 - \left(\dfrac{d \vec x}{d\tau}\right)^2##,
where ##ds## is the (invariant) infinitesimal spacetime interval, ##d\tau## is the (invariant) infinitesimal proper time interval, ##dt## is the (frame-dependent) infinitesimal coordinate time interval, and ##d \vec x## is the (frame-dependent) infinitesimal displacement.
In plain English, the left side is the (squared) "speed through spacetime" of something with mass. All observers agree on its value. The right side has two terms whose value depends on an observer's velocity relative to the massive object in question: the (squared) "speed through time" and the (squared) "proper velocity."
But this expression can be simplified. First, ##ds/d\tau = c##. Second, ##dt/d\tau = 1/\sqrt{1-v^2/c^2} = \gamma##. Third, ##d \vec x / d \tau = \gamma \vec v## (where ##\vec v## is normal velocity). So we have:
##c^2=(\gamma c)^2 - (\gamma \vec v)^2##.
This means that everything with mass always moves through spacetime with a "speed" of ##c##, where "speed" means the proper-time-derivative of the spacetime interval. As ##v## increases, both terms on the right side increase, and the first of them (the time contribution) is always the bigger of the two. So it's not quite true that "speed through time" decreases as ##v## increases.
What is true is that an object at rest has all of its "motion" through spacetime directed forward in time, whereas moving observers would say that the object moves through both space and time. All observers agree, however, that the difference of the squares of the space and time contributions equals ##c^2##, and that the object moves through spacetime at the ##\tau##-rate of ##c##.
AstroMath said:
Are they right?
It's one plausible way of visualizing the relationship between motion in space and paths in spacetime; and it captures the idea that you're always moving forward in time no matter what you do. It's not perfect (for example, either the speed through spacetime is not ##c## but instead ##\sqrt{-c^2}## - note that square root of a negative number - or you have to adopt a sign convention in which your speed through space is the square root of a negative number) and it's no substitute for understanding the underlying math.
So you can use it to form a mental picture to go with the math, but you can't build any deeper understanding on top of it.
Likes Chestermiller
Let me be more explicit in my post (#5 above).
(i.e., its 4-momentum vector can be normalized to a "unit" 4-velocity vector with Minkowski-norm c)
[and has spatial speed (slope) v in space].
Massless
(i.e., its 4-momentum vector has Minkowski-norm zero [and thus can't be normalized])
[and has spatial speed (slope) c in space].
Likes Battlemage!
AstroMath said:
Are they right?
It depends. Brian Greene, at least, when he makes this pitch in his pop science books, says something that isn't right. He says that all objects, including light, "move at c" in spacetime. But as robphy has pointed out, this isn't correct; it switches between two different interpretations of the term "speed through spacetime"--the norm of the 4-velocity in the case of massive objects, but the coordinate speed through space in an inertial frame in the case of light. This is a good example of a scientist saying something in a pop science book that he would never get away with in an actual peer-reviewed paper.
AstroMath said:
Are they right?
It's not about right or wrong , just about geometrical interpretations of the same math. The advance through space-time at const c can be visualized better in a space-propertime diagram:
http://www.adamtoons.de/physics/relativity.swf
Can the clock effect/twin paradox be displayed on this diagram? Or a uniformly accelerated observer?
Or is it restricted to inertial observers?
I think for a uniformly accelerated observer it would look cone-like, as shown here for a local observer hovering in a gravitational field:
http://demoweb.physics.ucla.edu/content/10-curved-spacetime
Also use gravity slider here:
Here the non-local picture for a radial line through the Schwarzshild-geometry (which is non-inertial).
http://www.adamtoons.de/physics/gravitation.swf
I guess you can transform any space-coordinate diagram into a space-propetime diagram. Here for the twins:
http://www.adamtoons.de/physics/twins.swf
For the twins with constant acceleration it should look somewhat like this:
The key is that the length of all worllines (in space-propertime) represents the passed coordiante time, so they all have equal length. This is the geometrical interpretation closest to the "all moves at c through space-time" meme, that I know of.
For a non-inertial observer in such a diagram, why would you not construct it so the 'defining observer' world line is vertical??!
It cannot be good for coincident events to be separated on diagram (this occurs even for the inertial frame twin scenario) ...
His world line is shown curved, because he is non-inertial.
Yes, that's something space-coordinate time diagrams show more directly.
You are being inconsistent here. If you are talking about "velocity through space" then massive objects have ##0\le v < c## and massless objects have ##v=c##. If you are talking about "velocity through spacetime" then massive objects have ##"v"=c## and massless objects have ##"v"=0##. In neither case do you get ##c## for both massive and massless objects.
If you don't like ##"v"=0## for light then you may want to move on to other topics besides this "velocity through spacetime".
Likes Battlemage! and Jeronimus
And what would you base your argument on? The tangent vector to the worldline of a light ray, which is the only feasible interpretation of the term "velocity through spacetime", is null; that means it has zero norm, so light's "velocity through spacetime" is indeed zero under this interpretation. The tangent vector to the worldline of a massive object, OTOH, has norm ##c##; that's what justifies the statement that massive objects have a "velocity through spacetime" of ##c##.
Another interpretation would be that the concept of "velocity through spacetime" doesn't make sense at all for light. But there is no interpretation I'm aware of under which light's "velocity through spacetime" is ##c##. Light's velocity through space is ##c##; but as Dale pointed out, you yourself were saying we should be careful not to confuse space with spacetime.
Can you elaborate a bit on this?
If as you say, when considering spacetime, massive objects move at c (always i assume), whereas light moves at 0 then it seems acceleration cannot exist any more in the sense of increasing or decreasing the speed of a massive object.
In the spacetime model, acceleration does not change the speed of a massive object; it only changes its direction. The norm of the object's 4-velocity never changes; it is always ##c##. But the direction in which the 4-velocity points in spacetime can change; that is what 4-acceleration does.
Why is something which does not affect the velocity of an object called acceleration? 4-acceleration in this case.
Velocity is a vector with both magnitude and direction. A change in either is change in velocity.
Likes Battlemage!
But is that really what is going on? Just a simple change of the direction of the velocity vector? What would prevent one then from pointing the vector to go backwards in time?
What prevents it? Nature. We're free to move in whatever spatial direction we choose, but we can only move forward in time. That's just how it is.
It does affect the velocity - the four-velocity and the four-acceleration are related by ##\vec{a}=\frac{d\vec{v}}{d\tau}## just as you'd expect. What doesn't change is the magnitude of the four-velocity, and that's because the four-acceleration is always perpendicular to the four-velocity.
Likes Battlemage!
The forward pointing in time directions are not smoothly connected to the backwards pointing directions. This is a result of the fact that there is only one time dimension compared to three space dimensions.
Likes Jeronimus
There is no four-acceleration that can turn a four-velocity that lies in the future light-cone into a four-velocity that lies in the past light cone.
We're getting into stuff that is hard to visualize without doing the math because the geometry of spacetime is Minkowskian not Euclidian.
Likes Battlemage!
Related to Stanford: objects in spacetime all move at constant speed c?
1. What is the significance of objects in spacetime moving at constant speed c at Stanford?
At Stanford, the constant speed c refers to the speed of light in a vacuum, which is approximately 299,792,458 meters per second. This speed is considered to be a fundamental constant of the universe and plays a crucial role in theories of relativity and the understanding of the laws of physics.
2. How does the concept of constant speed c affect our perception of time and space at Stanford?
The concept of constant speed c at Stanford is closely tied to the theory of relativity, which states that time and space are relative and can be affected by factors such as gravity and velocity. The constant speed c serves as a universal speed limit, implying that nothing can exceed this speed, even light. This has significant implications for our understanding of time and space.
3. Is the idea of constant speed c at Stanford proven by scientific evidence?
Yes, the concept of constant speed c at Stanford is supported by numerous experiments and observations, including the famous Michelson-Morley experiment, which demonstrated that the speed of light remains constant regardless of the observer's frame of reference. Additionally, Einstein's theory of relativity, which relies on the constant speed c, has been consistently validated through experiments and observations.
4. How does the concept of constant speed c at Stanford relate to the curvature of spacetime?
The constant speed c at Stanford is closely linked to the curvature of spacetime, as described by Einstein's theory of general relativity. According to this theory, the presence of mass or energy can cause a curvature in spacetime, which in turn affects the path of objects moving through it. The constant speed c serves as a fundamental limit for the curvature of spacetime.
5. Can objects at Stanford ever exceed the constant speed c?
No, according to the currently accepted laws of physics, it is impossible for any object to exceed the constant speed c at Stanford. This is because as an object's speed approaches the speed of light, its mass increases infinitely, making it impossible to accelerate to or exceed the constant speed c. This is known as the theory of special relativity.
