How Much Force Must the Biceps Generate in an Isometric Exercise?
In an isometric exercise for the biceps, an external force of 200 N is applied 0.3 meters from the elbow joint, requiring the biceps to generate sufficient force to counteract this torque. The moment arm for the biceps is 0.04 meters, while the weight of the forearm and hand adds an additional torque. Using the torque equilibrium equation, the required force from the biceps muscle is calculated to be approximately 20.6 N. The discussion emphasizes the balance of torques produced by the weight of the forearm, the external force, and the biceps force. Understanding these mechanics is crucial for effective strength training and injury prevention.
mwoods18
During an isometric exercise for strengthening the biceps, an external force of 200 N is applied perpendicular to the forearm 0.3 meters from the center of rotation of the elbow joint. The elbow is flexed to 90 degrees and the forearm is supinated. The force produced by the biceps muscle, which for our purposes is the only active muscle, has a moment arm of 0.04 meters and a line of application parallel to the long axis of the humerus. How large is the force (B) must the biceps muscle generate to counteract this torque? The weight of the forearm and hand is 13.7 Newtons and the length of the forearm and hand is 0.4 cm. The center of mass is 68% of the length of the forearm and hand from the elbow to the wrist.
Sum of Torque= 0
F*FA=R*RA
(0.028m)(200N)=(0.272m)(Fmuscle)
Fmuscle=20.6N
There are three forces that produce torques in this problem:
(1) weight of the forearm and hand (where does it act?)
(2) external force of 200 N (where does it act?)
(3) biceps force (where does it act?)
The torque due to the biceps force must balance the torques due to the other forces.
