Does Static Equilibrium Necessitate Zero Velocity?
Static equilibrium occurs when the net force and net torque on an object are both zero, resulting in zero acceleration. This raises the question of whether velocity must also be zero or if it can be constant. According to Newton's first law, an object at rest remains at rest unless acted upon by an external force, suggesting that a constant velocity is possible. Therefore, an object in static equilibrium can have a constant non-zero velocity without experiencing acceleration. Ultimately, static equilibrium does not necessitate zero velocity; it allows for both zero and constant velocity scenarios.
whitehorsey
1. What occurs during static equilibrium?
3. The net force and net torque on the object is zero. The acceleration of the object is zero too. Would velocity of the object also be zero? Or no because it has constant velocity?
Consider what Newton's first law states. A body at rest stays at rest or...?
Another way to consider it, is if the velocity is equal to zero or a constant, will there be a change in velocity and hence an acceleration?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
