Finding the Coefficient of Static Friction on a Banked Curve
To determine the coefficient of static friction for a car on a banked curve, the banking angle was calculated to be 24.7 degrees using the formula tan θ = v² / (r*g). The problem involves a car traveling at 93.8 km/hr on a curve with a radius of 87.5 m, and the goal is to find the necessary friction to prevent skidding. It is important to analyze the forces acting on the car, including the direction of friction, to ensure there is no vertical acceleration. A free body diagram can help visualize these forces and establish the conditions needed for the car to maintain its path without sliding.
mparsons06
If a curve with a radius of 87.5 m is perfectly banked for a car traveling 71.8 km/hr, what must be the coefficient of static friction for a car not to skid when traveling at 93.8 km/hr?
tan \theta = v^{2} / r*g
I found the banking angle:
tan \theta = 19.9^2 / 87.5 * 9.81 = 24.7 deg.
But I'm not sure on how to find what the question is asking for. Help?!
If there were no friction, would the car at that speed slide up or down the incline? The answer gives you the direction of the frictional force that is needed. Once you have the direction, draw a free body diagram and require that the acceleration have no vertical component.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
