Steady State Circuit Analysis with Phasors
5 replies · 3K views · last reply
alexmath
Hello everyone! I have the following circuit to solve, and my result is a bit wrong... can you tell me please where's the mistake?
E=10sin(1000t)
Find the current delivered to the circuit. Find the equivalent impedance of the circuit. Find the equation of the current and voltage drop for each element of the circuit.
I tried first to solve for the equivalent impedance.
Vrms=10/√2
Xc= -j * 1/wc
Xl = jwl
w=1000 rad/s
R1=100Ω, R2=20Ω, R3=50Ω, Xc=-100j, Xl=40j
therefore equivalent impedance is: 100+40j+ ((1/(50-100j))+0.05)^(-1)=40j+100, in polar form: 107.7 < 21.8, so the impedance=107.7/√2(1000t+ 21.8°)Ω.
Is that correct?
  • Circuit schematic with a sinusoidal source labeled epsilon on the left branch, a 100 ohm resistor on top, a 10 microfarad capacitor in the middle branch, a 50 ohm resistor below it, a 20 ohm resistor on the right, and a 40 mH inductor along the bottom.
Check your math on the impedance calculation. Your expression looks okay but your result does not.
alexmath said:
checked it on wolframalpha... what's wrong? :(
It's not the same as the result I get. Maybe break down your calculations and show some intermediate results? Start with the parallel combination of the 20 Ω resistor with the capacitor and 50 Ω resistor. What impedance do you get for those components ?
only two first components added up give 40j+100 ( i did not even check the calculation) , wolframalpha was wrong haha... the correct answer is:
123.47<17.53 right?
so the final impedance is 123.47 over sqrt 2 or not here? (1000t + 17.53 degrees converted in radians)
123.47<17.53 right?
Close enough! I'm seeing (extra digits kept for intermediate value to prevent roundoff/truncation errors creeping into future calculations) Z = 123.875 Ω ∠7.532° .
No root 2 involved in impedance ... RMS values apply to voltages and currents. Usually it's best just to convert the input voltage to an RMS value right at the start and then everything will take care of itself from then on.
In this problem, since you aren't calculating any powers (for which RMS values are key), you could get away with leaving the input voltage as 10 V (peak), do the calculations for the circuit, and write the time domain results as peak voltages.
Take care when you calculate the phase of the current! Your impedance is in the denominator of I = E/Z, so the angle of the current will be the negative of the angle of the impedance (assuming that the voltage E is the reference phasor with angle zero).
