How Fast Does the Center of Mass of a Falling Stick Move?
In summary: If it is going in circular motion it will experience a radially outward force.Isn't it?So i think due to this force the center of mass will have a translational motion too as there is no friction.Is that right??Yes, that's correct.
Tanya Sharma
1,540
135
A stick of mass M and length L is held vertically on a frictionless surface. A gentle push at the top causes the rod to fall from this position . Find the speed of its center of mass when it makes an angle θ with vertical .
a) Use force method
b) Use energy method
F=Ma
τ=Iα
First I tried using the Newtons laws of translation and rotation .
1) The forces acting in the vertical direction are Mg and Normal from the floor at the lower end (N) .
$$ Mg - N = Ma_{cm} $$
2) Writing torque equation about CM ,
$$ N\frac{L}{2}sinθ = \frac{ML^2}{12}\ddotθ $$
3) ycm = (L/2)cosθ
So , $$ v_{cm} = -\frac{L}{2}(\dotθsinθ) $$
and , $$ a_{cm} = -\frac{L}{2}[\ddotθsinθ + (\dotθ^2)cosθ] $$
Using the above three equations,I end up with
$$ a_{cm} = \frac{1}{1-3sin^2θ}(-3gsin^2θ - \frac{L}{2}\dotθ^2cosθ ) $$
But I need to find relation between vcm and θ .
I would be grateful if somebody could help me with the problem .
There was a thread about this problem a couple of days ago, where the same (difficult) approach was used.
I suggest using energy.
You can write up acm also in terms of theta and derivatives. Then apply the trick that d2θ/dt2= dω/dt = (dω/dθ) ω =0.5 d(ω2)/dθ. You can consider ω2 a new variable, say z, and you get a first order linear equation for it (hopefully) .
ehild
Likes 1 person
ehild
Is it something different from $$ a_{cm} = -\frac{L}{2}[\ddotθsinθ + (\dotθ^2)cosθ] $$ ?
Are the three equations I have formed correct and relevant ?
I meant to write a de for theta.
ehild
As I read the OP, the requirement is to solve it twice, once using energy and once using forces.
ehild
Okay ...this is what i get
$$\frac{L}{6sinθ}(3sin^2θ-1)\ddotθ + \frac{L}{2}cosθ\dotθ^2 + g = 0 $$
Putting θ '' = ωdω/dθ and θ' = ω
$$ \frac{L}{6sinθ}(3sin^2θ-1)ω\frac{dω}{dθ} + \frac{L}{2}cosθω^2 + g = 0 $$
Is it correct ?
are you considering the translational velocity of the center of mass?
I am too trying to solve this problem.
vcm is the velocity of center of mass .
I mean that the rod as a whole is also moving in horizontal direction(as there is no friction). I don't see you have considered this velocity.
Why would it move horizontally?
Please wait for some time before you put forward any query or suggestions...
a) Use force method
F=Ma
τ=Iα
3) ycm = (L/2)cosθ
I miss a picture...
If the origin is at the ground just below the CM, the y-axis points upward, and then macm=d2ycm/dt2=N-mg.
Using acm and vcm is confusing, use the derivatives of y, and check the signs.
At the end, use ω2 as variable, function of theta.
ehild
Likes 1 person
Is it correct ?
Check the signs. Read my previous post.
ωdω/dθ=0.5 d(ω2/dθ). You have a first order equation for ω2, easy to solve.
ehild
ehild said:
I miss a picture...
Here is the picture
Ok, I have the same picture.
ehild
$$ \frac{(3sin^2θ+1)}{(12sinθ)}\frac{dz}{dθ} + \frac{L}{2}(cosθ) z - g =0 $$
Does this makes sense ?
You miss an L in the first term. Otherwise it is OK :thumbs:
ehild
If there is no friction, the net horizontal force is zero. So the horizontal momentum is conserved. We can choose an inertial reference frame where the rod has no horizontal motion.
thanks i got it.:thumbs:
Sorry for interrupting you thread:frown:
ehild...By applying method of separation of variables ; z =u(θ)v(θ)
v(θ) = C1/(3sin2θ + 1)
u(θ) = (-12gcosθ)/(LC1) + C2
This doesn't give me correct answer ...Is this what you are getting or something else?
One integration constant is enough, you can take C1=1.
It looks correct, although I did not check the constants. So uv=ω2, and ω=0 at θ=0. Find the constant, then calculate ω at θ=pi/2.
ehild
ehild
Constant C = 12g/L
ω2 = 12g(1-cosθ)/[L(3sin2θ+1)] .This doesn't seem to be right.
Why ? What has θ=pi/2 to do ?
Sorry, I thought you need the final velocity. Why do you think it is not right?
ehild
So, $$ ω^2 = \frac{12g(1-cosθ)}{L(3sin^2θ+1)} $$ looks alright to you ?
And then
gives $$ ω = -[\frac{3gL(1-cosθ)(sinθ)}{(3sin^2θ+1)}]^\frac{1}{2} $$
Is this fine ?
I got the same result with the energy method.
Why are we getting a minus sign ?
  • #31
I like it :smile:
Tanya Sharma said:
And then
Is this fine ?
why minus? And you miss a factor of 2. $$ ω =2\sqrt{ \frac{3g(1-cosθ)}{L(3sin^2θ+1)} }$$
and Vcm=-ωsinθ L/2.
  • #32
Oh ! that was a typo..I meant
$$ v_{cm} = -[\frac{3gL(1-cosθ)(sinθ)}{(3sin^2θ+1)}]^\frac{1}{2} $$
Minus makes perfect sense...
  • #33
$$ v_{cm} = -[\frac{3gL(1-cosθ)(sin^2θ)}{(3sin^2θ+1)}]^\frac{1}{2} $$
sinθ has to be squared if you pull it under the square root. But otherwise it is perfect:thumbs: Have a good rest, you deserve it. :smile:
ehild
Likes 1 person
  • #34
ehild...I am falling short of words to express my gratitude...All I will say is "THANK YOU ehild" .
You rock! :smile:
  • #35
You rock! :smile:
You are welcome. That was a challenging problem. I am also exhausted :smile:
ehild
1. What causes a stick to fall?
A stick can fall due to a variety of factors, such as being pushed or pulled by an external force, losing balance, or being affected by gravity.
2. How does friction affect the slipping of a stick?
Friction is the force that resists motion between two surfaces in contact. When a stick is slipping, the friction between the stick and the surface it is slipping on can either help to slow down or stop the stick, or it can cause the stick to continue slipping.
3. Can the shape of a stick affect its likelihood of falling or slipping?
Yes, the shape of a stick can play a role in its stability and likelihood of falling or slipping. A stick with a larger base or a wider shape will have a lower center of gravity, making it less likely to fall. Additionally, a stick with a rougher surface may have more friction and be less likely to slip.
4. How can we prevent a stick from falling or slipping?
There are several ways to prevent a stick from falling or slipping, including increasing friction by roughening the surface it is resting on, or adding weight to the base of the stick to lower its center of gravity. Additionally, proper handling and positioning of the stick can also prevent it from falling or slipping.
5. What are some real-life applications of studying stick falling and slipping?
Studying stick falling and slipping can have practical applications in various fields, such as engineering, construction, and sports. Understanding the factors that affect the stability of a stick can help engineers design more stable structures, while understanding friction can help athletes improve their performance in sports that involve sticks, such as hockey or lacrosse.
16K
