Stone is dropped from the top of a cliff
  • Thread starter Thread starter Alice
A stone is dropped from a cliff and takes 3.66 seconds to hit the ground, prompting a discussion on how to calculate the height of the cliff. The initial velocity is zero, and the final position is ground level, indicating that gravitational acceleration is at play. Participants suggest using the kinematic equations for constant acceleration to relate the variables involved. The key equation discussed is the one that incorporates displacement, time, and acceleration, which can be adapted for vertical motion. By substituting the appropriate values, the height of the cliff can be determined.
Alice
Hey
This seems to be way easy, but I'm just not gettng where to start it. A stone is dropped from the top of a cliff, it is seen to hit the ground below after 3.66 s, how high is the cliff? Anyone know? Thanks.
That means that vi=0, and the yi the height of the cliff, which is unknown. Implicit in this is that the acceleration of the stone is that of gravity.
That means that Δt=3.66s. Implicit in that is that yf=0, which is ground level.
Can you find an equation that relates those quantities?
Mentor Edit: Please don't post complete solutions. Thank you.[/color]
Tom-
I pretty much got that far on my own. I just don't know which formula ot use. The one that looks the closes would be
/\=Delta
/\X=X-Xo=VoxT+1/2AxT^2
and
Vx^2-Vox^2=2Ax/\x
but I'm not sure. I'm having a really hard time figuring out which formula goes where. Thanks.
-Alice
This one always works for a constant acceleration. And, of course, that "X" doesn't have to be horizontal.
Right, the equation also holds for "y".
Alice, look at the equation that turin referred to, rewrite it for y (just replace x with y), and verify that you do in fact have all the information to solve the problem. Then, plug in the numbers.
