Understanding Real Gas Behavior: Deviations from Ideal Gas Equation
  • Thread starter Thread starter rumaithya
    Behavior
Continuing to lower the temperature of a real gas, specifically an air mixture of nitrogen and oxygen, leads to significant deviations from ideal gas behavior at temperatures of 90 K and 77 K. These temperatures correspond to the boiling points of nitrogen and oxygen, respectively. As the temperature decreases, gas molecules transition from the vapor phase to the liquid phase, resulting in sudden drops in pressure. This phenomenon highlights the limitations of the ideal gas equation, particularly during phase changes, where the behavior of real gases diverges from theoretical predictions.
rumaithya
If you had continued to reduce the temperature of your real gas in this experiment (air mixture of mostly nitrogen and oxygen) to lower and lower temperatures, you would observe sudden drops in pressure at 90 K and 77 K. In other words, the behavior of the real gas would deviate significantly from the predicted straight-line behavior of the ideal gas equation determined in Question 3 and your extrapolated graph. Why ? [Hint: Consider what happens to water vapor(H2O(g)) when it is cooled to 0.0 C.]
Could anyone explain this, please ?
Chemistry news on Phys.org
Question 3
Where is this mysterious question 3...
Phase change
The temperatures 77 & 90 °K correspond to the liquefaction (boiling points) of Oxygen & Nitrogen respectively.
The pressure drops due to the removal of gas molecules from the vapour phase into the more condensed phase of liquid.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
