Strength of Electric Field with a point charge
The discussion centers on calculating the strength of the electric field created by a +11 nC charge located at the origin, specifically at the coordinates (-5 cm, 5 cm). Participants express confusion regarding the correct application of the electric field formula, E = k|q|/r², for both the x and y axes. There is also a clarification needed about what is meant by "a 11 charge," indicating a potential misunderstanding of the charge's value. The calculations involve combining the electric field components from both axes to find the resultant field strength. Overall, the thread highlights common challenges in applying electric field equations in two-dimensional scenarios.
ltruiz45
Problem:
A +11 nC charge is located at the origin.
Question:
What is the strength of the electric field at the position x,y (-5cm, 5cm) ?
I would think you would do this but when I try it I get the wrong answer
for x-axis - E=k|q|/r2
For y-axis - E=k|q|/r2
Then \sqrt{}Ex^2 + Ey^2
ltruiz45 said:
Problem:
A 11 charge is located at the origin.
What is "a 11 charge"?
Question:
What is the strength of the electric field at the position ?
At what position?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
