Strength of magnetic field required to balance gravitational force
To balance the gravitational force on a charged particle moving parallel to the Earth's surface, the relevant equation is Bqv = mg, where B is the magnetic field strength, q is the charge, v is the velocity, and mg is the weight of the particle. Participants in the discussion emphasize the importance of understanding the underlying concepts before applying equations. There is a consensus that the original poster should demonstrate some effort in solving the problem by attempting to use the correct formula. Clarifications about the variables involved are also highlighted, as accurate notation is crucial for dimensional consistency. The discussion stresses the need for foundational knowledge in physics to effectively tackle such problems.
astru025
A particle with charge q = 4.00 10-6 C and mass m = 1.30 10-4 kg is moving parallel to the Earth's surface at a speed of 1000 m/s. What minimum strength of magnetic field would be required to balance the gravitational force on the particle?
Not sure where to begin... Any help would be really nice! Thanks.
Begin by looking at the equations for force due to a magnetic field and force due to gravity.
try vB=mg!
Shyan said:
try vB=mg!
This is not even dimensionally consistent. Perhaps you ment ##Bqv = mg##. But as a general rule, I've found that just throwing equations at the OP before it's clear he/she understands the underlying concepts is a bad idea.
Forum policy is that you have to show some effort. Start with xophergrunge's suggestion. Then write down any equations you think might be helpful.
Yeah sorry,I forgot the q.
But if s\he's given a problem like that,it means s\he was given the equation and its meaning before!
And if that's the case, s\he can at least make a start on solving the problem and show us what s\he has done!
