Stress Mechanics Link AB: -20 ksi, 12 ksi Pins: Diameter + Bearing Stress
  • Thread starter Thread starter eaon21
    Mechanics Stress
The discussion centers on calculating the diameter of pins and average bearing stress in Link AB, which supports a horizontal beam. The average normal stress is given as -20 ksi, while the average shearing stress in the pins is 12 ksi. Participants express confusion about the relationship between normal and shear stress, particularly regarding the areas involved in the calculations. There is an emphasis on equating the forces related to normal and shear stress to solve for the unknowns. Understanding the area under both stress types is crucial for accurate calculations.
eaon21
Link AB, of width b = 2 in. and thickness t = 1/4 in., is used to support the end of a horizontal beam. Knowing that the average normal stress in the link is -20 ksi, and that the average shearing stress in each of the two pins iS 12 ksi, determine (a) the diameter d of the pins, (b) the average bearing stress in the link.
This is not for homework questions. Even so, you need to show some effort on your part. Show us what you think and have tried first.
im sorry..i was just answering questions in my book for my upcoming exam...
actually..my biggest concern right now is the area under the normal and shear stress..im still confused... though i think that this problem will be solved by equating the formulas for shear and normal stress since they will have the same P, right? i have the normal stress and shear stress average..i can equate the two P's..how about the areas in each stresses?
(that is for question letter a, still not thinking about letter b)
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
