Stress of a material with a core
To determine the stress in a rod with a steel core and aluminum shell under temperature changes, it's essential to equate the deformations of both materials. Simply calculating the stress for each material separately and adding them may lead to inaccuracies. The correct approach involves understanding how the different thermal expansions affect the overall stress distribution. By ensuring that the deformations match, one can accurately assess the induced stresses. This method provides a reliable solution for composite materials under thermal stress.
joeblow
If I have a rod with a steel core bonded to an aluminum shell, how can I find the stress in the rod when it is subjected to a temperature change?
I know how to find the stress due to temp change if the tool is made of the same material throughout, but how do I do it if there are two?
I attempted to find the loads induced by the temp changes for the two materials separately, add them, then find the stress that way, but this led to an incorrect answer.
Figured it out. PROTIP: Equate the deformations of both materials.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
