Studying for exam- telescope problem (help )
To resolve a lunar lander measuring 3 meters across from Earth, the required diameter of an optical telescope can be calculated using the formula theta = 1.22 * lambda / d. A typical wavelength (lambda) in the visible spectrum should be assumed for the calculation. The angular separation (theta) can be determined by dividing the size of the lander by its distance from Earth, which is 3.8e8 meters. This approach provides a method to find the necessary telescope diameter for resolving the lander. The discussion emphasizes understanding angular separation in relation to telescope optics.
twinkle24
studying for exam- telescope problem (help!)
What diameter optical telescope on the Earth would you need to resolve a lunar lander 3 m across on the surface of the moon 3.8e8m away?
the only thing I can think of is to use theta=1.22lamda/d... but what do I do with it? help!
You need to assume a typical value for lambda. A wavelength in the visible spectrum.
d is the diameter you need to calculate.
theta is the angular separation of two points that can just be resolved.
What is the angular separation of those two points on the moon?
oh! that makes sense. so is the angular separation the size of the lander divided by the distance to it?
That should work fine.
(Welcome to Physics Forums, by the way)
yay! thank you!
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
