STUDYING FOR TEST, need a tutortial
  • Thread starter Thread starter ElectricMile
    Studying Test
The discussion revolves around understanding the derivation of the escape velocity formula for a rocket. The key equation K2 + U2 = K1 + U1 simplifies to (1/2)m*v^2 = GMm/R, where K2 and U2 are zero at infinity, indicating that the rocket must have enough kinetic energy to escape Earth's gravitational pull. By dividing both sides by m and manipulating the equation, the escape velocity is derived as v = sqrt(2GM/R). The participants clarify that the mass m cancels out, allowing the equation to focus solely on gravitational constants and distance. This discussion emphasizes the importance of understanding energy conservation in gravitational fields to grasp escape velocity concepts.
ElectricMile
ok..haveing trouble understanding some examples in the book...
1) 1000kg rocket is fired striat up, need rocket to escape and never return. what speen does rocket need to escape from grav pull to never come back?(non rotating earth)
i know rocket can't stop so or it will be drawn back into earth. so...
K2+U2=K1+U1 is:
0+0=(1/2)m*v^2 - (GMm)/R)
whats with the 0+0?
then it goes to:
Vescape= v1 = SQRT(2GM/R)
howd they get to that equation??
i know the answers and stuff its in the book, i just don't know how they got to those equations
For escape velocity, you only need enough speed so that you escape the gravitational potential of the object. Therefore, any kinetic energy at infinity would be wasteful. So K2 = 0. U2 = 0 because the gravitational potential falls off like 1/r which goes to zero at infinity.
So we have (1/2)m*v^2 = GmM/R
so v^2 = 2GM/R
v = sqrt(2GM/R)
still not sure how you got rid of the 1/2...and did the m just cancel out on each side?
(1/2)m*v^2 = GmM/R
1] Divide both sides by m
(1/2)*v^2 = GM/R
2] Times both sides by 2
v^2 = 2GM/R
3] Take the root
v = sqrt(2GM/R)
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
