Chemistry Suggestions for Chemistry 1 Self-Study Books?
For students preparing for Chemistry 1, several study book recommendations emerged. "Chemical Principles: The Quest for Insight" by Atkins and "Principles of Modern Chemistry" by Oxtoby are highlighted for their thoroughness and mathematical orientation, making them suitable for brushing up on essential concepts. Additionally, using 'Arihant' books is suggested for a solid review of chemistry fundamentals. Following up with MIT's chemistry course is also recommended for in-depth explanations and a deeper understanding of the subject. The solution manual for "Chemical Principles" is noted for its comprehensive explanations, enhancing the learning experience.
k1316
I will be taking Chemistry 1 in the fall for undergrad science majors and am looking for a good study book to brush up on the basics. I took chemistry in high school two years ago and don't want to be re-learning basics that I was expected to know beforehand (sig figs, conversions, etc). Any suggestions for a study book to help prepare me a little more?
Thanks for any and all help!
You could use 'Arihant' books they're a good set of books to recollect ur chemistry knowledge! It's only a suggestion!
I strongly recommend "Chemical Principles: The Quest for Insight" by Atkins and "Principles of Modern a Chemistry" by Oxtoby! Very through, detailed, and mathematically oriented!
I second that. It's a great book, Then you can follow MIT's course on chemistry: One of the best courses around (you really get some good and quite deep explanations)
The solution manual to Chemical principles i GREAT, and full of explanations to :)
The book is fascinating. If your education includes a typical math degree curriculum, with Lebesgue integration, functional analysis, etc, it teaches QFT with only a passing acquaintance of ordinary QM you would get at HS. However, I would read Lenny Susskind's book on QM first. Purchased a copy straight away, but it will not arrive until the end of December; however, Scribd has a PDF I am now studying. The first part introduces distribution theory (and other related concepts), which...
I've gone through the Standard turbulence textbooks such as Pope's Turbulent Flows and Wilcox' Turbulent modelling for CFD which mostly Covers RANS and the closure models. I want to jump more into DNS but most of the work i've been able to come across is too "practical" and not much explanation of the theory behind it. I wonder if there is a book that takes a theoretical approach to Turbulence starting from the full Navier Stokes Equations and developing from there, instead of jumping from...
