Finding the PDF of the Sum of Two Random Variables: Uniform Distribution
In summary: Draw a diagram of the event space, putting the two random variables on the x and y axes. Draw a line through it representing the sum having some given value.It will not in general be a triangle.
nikki92
40
X is uniform [e,f] and Y is uniform [g,h]
find the pdf of Z=X+Y
f_z (t) = f_x (x) f_y (t-x) ie convolution
Obviously the lower pound is e+g and the upper bound is f+h
so it is a triangle from e+g to f+h. The tip of the triangle still in the center of the distribution i.e. .5[e+g+f+h)
so would the pdf be t for e+g< t < .5[e+g+f+h]
g+h - t for .5[e+g+f+h] <t <g+h
and 0 otherwise?
And you get a blizzard of cases depending on the relative sizes of e,f,g,h.
I am confused. Originally I wanted to take the characteristic equation, but the inverse Fourier transformation to avoid cases. Do I have to assume each case when e,f,g,h, <0 and e,f,g < 0 and h> 0 ... etc all combination of events and maybe = 0 ? There seems to be way too much work for this problem and what confuses me is that the teacher said it formed a triangle.
There are only two cases that you need to consider: (1) ##f-e \leq h-g## and (2) ##f-e > h-g##. In each case, the pdf of ##Z## can be specified piecewise. As noted, it will be a triangle if ##f-e = h-g##. In general, it will be another geometric shape. (Hint: the pdfs of ##X## and ##Y## are rectangular. Suppose one rectangle is narrower than the other. What happens with the convolution at offsets where the narrower rectangle's base is contained within the wider rectangle's base?)
By the way, the original post doesn't mention whether ##X## and ##Y## are independent. The pdf of ##Z = X+Y## is not necessarily a convolution if this is not the case.
Likes 1 person
and 0 otherwise?
It is straigtforward to get a solution to the general case here by using Laplace transforms, provided that you allow negative values, if necessary; that is, regard the Laplace transform as being ##\int_{-\infty}^{\infty} e^{-sx} f(x) \, dx## for functions that are zero for ##x < -M## for some finite ##M > 0##. Alternatively, assume your e,f,g,h are all ≥ 0 by shifting everything to the right if need be. You can re-write the LT of the sum as a sum of four easily-inverted LTs, resulting in things involving Heaviside functions; these will take care of all the possible "cases".
Likes 1 person
What is the "sum of two random variables"?
The sum of two random variables is a mathematical concept that describes the result of adding two random variables together. It is a way to combine two sources of randomness and analyze their combined behavior.
How is the sum of two random variables calculated?
The sum of two random variables is calculated by adding the values of the two variables together. This can be done by adding the individual probabilities of each variable or by using a formula specific to the type of random variables being added.
What is the significance of the sum of two random variables in statistics?
The sum of two random variables is important in statistics because it allows us to model and analyze complex systems that involve multiple sources of randomness. It also helps us understand the distribution and behavior of the combined variables.
Can the sum of two random variables be used to predict future outcomes?
No, the sum of two random variables cannot be used to predict future outcomes. Random variables by definition are unpredictable and the sum of two random variables only describes the combined behavior, not future outcomes.
What are some real-world applications of the sum of two random variables?
The sum of two random variables has many applications in fields such as finance, economics, and engineering. For example, it can be used to model stock prices, estimate risk in investment portfolios, and analyze the reliability of complex systems.
