Calculating Drop Size, Number and Time for Water Flow Through Capillary
The discussion revolves around calculating the radius of water droplets, the number of droplets from 10g of water, and the time required for the water to flow through a capillary tube. The user attempts to derive equations based on the balance of forces acting on a droplet at the end of the tube, incorporating parameters like surface tension and the density of water. The user expresses uncertainty about their approach and seeks validation of their calculations. There is a suggestion to consolidate thoughts into fewer posts to enhance clarity. The conversation emphasizes the need for a clear understanding of fluid dynamics principles in this context.
10bunny10
Trough a capillary with an inner radius r=1mm water flows in a form of small spherical droplets. What is the radius of the drops, the number of drops in m=10g water and the time needed the water to expire, if the surface tension of the water is =72x10^-3N/m, and the period between two drops is t=2s.
I need an idea how to imagine the situation and what to take into consideration? Help please :/
I tried something:
When the drop is at the end of the tube just before to fall
αl1+αl2=m0g
where m0 is the mass of one drop
2απr+2απR=m0g
R=m0g2απr/2απ
V0=4R3π/3
m0=ρV0
m0=4ρR3π/3
N=m/m0
N=3m/4ρR3π
τ=t3m/4ρR3π
t=2s
Here is how I imagined it.
Can anybody tell me if it is correct please?
You could've just used the edit button instead of posting 4 times on this thread that you pretty much just started.
