Taking the integral of xe^ax^2
  • Thread starter Thread starter ilikesoldat
    Integral
The discussion revolves around solving the differential equation dy/dx = x * e^(ax^2), focusing on the integration of the expression involving the variable x and the constant a in the exponent.
  • Participants discuss various attempts to integrate the expression, including substitution methods. Questions arise regarding the assumption that a is a constant and the implications of this assumption on the problem-solving process.
There is an ongoing exploration of the assumptions regarding the constant a, with some participants providing insights into standard conventions in mathematical notation. Multiple interpretations of the original question are being examined, particularly regarding the clarity of the integration request.
Participants express concern over the ambiguity in the phrasing of the original problem, debating whether the integration should be interpreted as a definite task or if it allows for broader interpretations. The distinction between variables and constants in mathematical expressions is also under scrutiny.
ilikesoldat
dy/dx=x*e^(ax^2)
solve the differential equation
integral of e^x=e^x
im not really sure how to do it when there are two variables in the exponent? i tried several things like u=x^2 1/2du=xdx then 1/2*int[e^a*u] results, but i can't take the integral without a different substitution since int[e^a*u] is not = to e^a*u.
the answer is 1/2a * e^ax^2 + C.. any methods to integrate this? several methods would be best
Think about how you compute [tex]\frac{d}{dx}e^{f(x)}[/tex]
a is a constant, keep that in mind . . .
I solved it with a as a constant and got the right answer, but . . .
How do i know a is a constant? I can't just assume that can I? What is the proof for a being a constant
Because a is assumed to be a constant in these situations, just as how [itex]\pi[/itex] nearly always represents the irrational number, but in some other cases, it can be mean something completely different, such as representing a product.
And if it wasn't a constant, then you can't solve the problem. So which do you think is more likely? :-p
Was the question just "integrate [itex]xe^{ax}[/itex]" or was it to find [itex]\int xe^{ax}dx[/itex]?
That makes sense but it still bugs me to just assume it is a constant :(
And to the other person, the question was
dy/dx=x*e^(ax^2)
solve the differential equation, so yes it would be integral of x*e^ax^2 dx (except you forgot the squared on top of the x in e's exponent)
thanks for everybody's help
The situation is no different than if you were told to solve dy/dx = a .
What's the difference?
HallsofIvy said:
Was the question just "integrate [itex]xe^{ax^2}[/itex]" or was it to find [itex]\int xe^{ax^2}dx[/itex]?
The second, [itex]\int xe^{ax^2} dx[/itex], makes it explicit that the 'variable of integration' is x ("dx") while the first, "integrate [itex]xe^{ax^2}[/itex]", is ambiguous. Of course, it is a standard convention that such things as "x", "y", "z" are used as variables while such things as "a", "b", "c", etc. are used to denote constants.
If it were [itex]\int xe^{ax^2}da[/itex], it would be [itex](1/x)\int e^{ax^2}+ C[/itex].
Yes, but without those standard conventions then we could just as well argue that a=f(x) in the integrand, just as the OP has done.
  • · Replies 21 ·
  • · Replies 105 ·
12K
