Taking the limit of this as s-> 0 (algebra based)
  • Thread starter Thread starter rela
    Limit
rela
Hi all, this may sound trivial but I've been like cranking my brains on this. Probably I just can't see it. Will need someone to shed some light.
Taking the limit of [(1/s)(a-b)/(s^2 + cs + a)] as s-> 0
Stated above
By using L'Hopital rule, I know this limit tends to 0 itself. However, I just can't manipulate the expression algebraically to obtain the same limit of 0. I'm just unable to cancel out that 'solo' s at the denominator. Hence, it appears to me that the limit shoots up to infinity as s-> 0 through algebraic means. I know this is incorrect but I just couldn't figure it out.
Please kindly help me in guiding me along.
Thanks!
Stated above
Thanks!
You can't use l'Hopital's rule here, because the fraction is not of the form "0/0" or "inf/inf". I understadn what you wrote as
<br /> \lim_{s\to 0}\frac{\frac{1}{s}(a-b)}{s^2+cs+a}<br />
The numerator tends to infinity, the denominator however tends to a, so yes, the expression "blows up" as s-->0.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
