Teach me to fish outward force ball on string
  • Thread starter Thread starter creationvger
    Ball Force String
The discussion focuses on calculating the outward force exerted by a 2-pound ball on an 18-inch string spun at 2000 RPM. The formula mentioned is F = M * V² / r, but the user seeks clarification on the calculations involved. They express a desire for a detailed, step-by-step explanation to understand the math for a project. Additional links to resources are provided, but the user emphasizes the need for a comprehensive example to learn effectively. The conversation highlights the importance of clear guidance in mastering physics concepts.
creationvger
I am requesting a precise step by step calculation for the outward force of a 2 pound ball on an 18 inch string being spun at 2000 rpm.
I know it's F = M times V squared devided by radius; but I must be excluding something important in the formula.
I need it to learn the math for a project. If u will show me each step using english measurements I would be very thankful.
Yes that did help in that I used the form to do math. However I'm not allways on the net; I have not yet, "learned" to fish. If someone would like to take the time to work the full math out providing me with a sample including clarification of each move, I would greatly appreciate it and gladly take it from there.. However I am thankful for ur help as I truly can use what u provided at the moment. Also 2 of ur addresses were the same. Did not know if u meant to put 3 up or not.. Once again, thank you.
Yes 2 are the same link, but I wanted to draw attention to both anchors on the page.
Got it and learned.. ThanX!
