Temperature Change: Convert 29°F to C and K
In summary, the outside temperature increased by 29°F between the early morning jog and lunch at noon. To find the corresponding change in temperature in Celsius, you would use the equation Tc = (5/9)(Tf - 32) which gives a result of -1.66667°C. This answer is correct as it only takes into account the change in temperature and not the zero points of the scales.
planke
One day you notice that the outside temperature increased by 29° F between your early morning jog and your lunch at noon. What is the corresponding change in temperature in each of the following scales?
_____C
_____K
Tc = (5/9)(Tf - 32)
T (kelvin) = Tc + 273.15
Ti + 29F = Tf
Tf-Ti = 29F
Tc = (5/9)(29-32) = -1.66667C
I am confused to why this answer is incorrect.
If you are only interested in a change of temperature you don't care about the zero points of the scales, you just need to know how many F is a C - and so how many C in 29F
1. How do you convert Fahrenheit to Celsius and Kelvin?
To convert Fahrenheit to Celsius, subtract 32 from the Fahrenheit temperature, then multiply by 5/9. To convert Fahrenheit to Kelvin, add 459.67 to the Fahrenheit temperature, then multiply by 5/9.
2. What is the formula for converting Fahrenheit to Celsius and Kelvin?
The formula for converting Fahrenheit to Celsius is (°F - 32) x 5/9, and the formula for converting Fahrenheit to Kelvin is (°F + 459.67) x 5/9.
3. What is the freezing point of water in Fahrenheit, Celsius, and Kelvin?
The freezing point of water is 32°F, 0°C, and 273.15K.
4. What is the significance of converting temperature from Fahrenheit to Celsius and Kelvin?
Converting temperature from Fahrenheit to Celsius and Kelvin allows for easier comparison of temperature measurements across different systems. It also allows for more accurate and precise measurements in scientific experiments and research.
5. Can you convert any temperature from Fahrenheit to Celsius and Kelvin?
Yes, any temperature measurement in Fahrenheit can be converted to Celsius and Kelvin using the appropriate formula and calculations.
