Comparing Temperature Ranges: Fahrenheit vs. Celsius
In summary, converting a change of 10 degrees in both Fahrenheit and Celsius shows that Fahrenheit has a greater range of 170 compared to 90 in Celsius, making Fahrenheit the larger temperature range.
mike2007
46
Which spans a greater temperature range, a change in temperature os 10 Fahrenheit degrees or a change in 10 Celcius degrees?
Using 0 and 100 degrees C and 32 and 212F as references show that a change in 10 degrees Celsius gives a temperature range of 90 (100 – 10). A change in 10 F gives a range of 170 (212-42), so Fahrenheit spans a greater range in temperature.
Is that a Question to mislead you or am on the right track.
The simple way to do this is to convert one into the other; i.e. convert 10 degrees Fahrenheit into degrees celcius. Then you have each measurement in the same units, and so can compare the size of the numbers. So, do you know how to convert degrees Fahrenheit into degrees celcius?
10 degrees C is 1/10 of the distance from freezing to boiling (10/(100-0)). 10 degrees F is 1/18 of the distance from freezing to boiling (10/(212-32)). Which spans a greater range? Your calculation of 'range' has nothing to do with what I would think of as a 'range'.
So the conversion of 10 degrees is 10/100 = 0.1
the conversion to degrees F is 10/180 = 0.0555
The one that has the greater range is degrees?
They are both 'degrees'. The celsius range (1/10) is greater than the fahrenheit range (1/18) of the same interval. But I was just trying to make some sense out of your calc. To avoid confusion and be more straightforward just do as Christo suggests. Convert 10 degrees C to degrees F and see if it is larger than 10 degrees F.
I don't think it is intended to mislead you but I think you are misinterpreting the question. A "change in 10 degrees Celsius" does NOT "give a temperature range of of 90". You appear to be thinking "change 0 to 100 to 10 to 100". What they mean is "what happens if the temperature changes 10 degrees?" That is, suppose the temperature is 40 degrees Celsius and changes to 50 degrees Celsius. Is that a large a temperature change as if the temperature changes from 40 degrees Fahrenheit to 50 degrees Fahrenheit?
You know that, in the Celsius scale, water freezes at 0 degrees and boils at 100 degrees. A 10 degree change is 10% of that. In the Fahrenheit scale, water boilds at 32 degrees and boils at 212 degrees. That same change in actual temperature corresponds to a change of 212- 32= 180 degrees Fahrenheit. A 10 degree change is 10/180= 1/18 of that.
So which is a larger change in "actual" temperature? A change of 10 degrees Celsius or a change of 10 degrees Fahrenheit?
converting one into the other
50 F to 60F = 10 to 15.555
50 Celsius to 60 Celsius =122 to 140
So therefore degrees Celsius has the greater range
You don't need to convert both. Just convert C to F or vice versa. Not both. One degree C=9/5 degree F. Does that help?
yes that makes it clearer now. thanks
are you mike27 at another forum?
No i am not mike27 on a different forum.
Related to Comparing Temperature Ranges: Fahrenheit vs. Celsius
1. What is the ideal temperature range for human comfort?
The ideal temperature range for human comfort is typically between 68-72°F (20-22°C). However, this can vary slightly depending on personal preference and other factors such as humidity and air circulation.
2. What is the difference between high and low temperature ranges?
The high temperature range refers to the upper limit of temperatures that can be reached in a particular environment, while the low temperature range refers to the lower limit. These ranges can vary depending on the location and time of year.
3. How does temperature range affect plant growth?
The temperature range can greatly impact plant growth as different plants have different temperature preferences. Generally, most plants thrive in temperatures between 65-75°F (18-24°C), but this can vary depending on the type of plant and its specific growing conditions.
4. Can extreme temperature ranges be harmful to the body?
Yes, extreme temperature ranges can be harmful to the body. Exposure to high temperatures for extended periods of time can lead to heat exhaustion or heat stroke, while exposure to low temperatures can lead to hypothermia. It is important to take precautions and dress appropriately in extreme temperatures.
5. How does temperature range affect weather patterns?
The temperature range is one of the main factors that contribute to weather patterns. Differences in temperature can cause changes in air pressure, wind patterns, and the formation of clouds and precipitation. Extreme temperature ranges can also lead to severe weather events such as heat waves or cold snaps.
10K
12K
19K
