How Do You Calculate Tensions T1 and T2 in a Two-Cable System?
  • Thread starter Thread starter Demianu27
    Tension
To calculate the tensions T1 and T2 in a two-cable system supporting a 58N weight, the correct approach involves using the equations of equilibrium. The horizontal force equation is T2 - T1cos60 = 0, and the vertical force equation is T1sin60 - 58N = 0. Solving these equations correctly reveals that T1 can be calculated as T1 = 58N / sin 60°, and subsequently, T2 can be found using T2 = T1 * cos 60°. The discussion highlights the importance of correctly identifying the angle's reference point to apply the sine and cosine functions accurately. Overall, understanding the relationships between the forces is crucial for solving the problem effectively.
Demianu27
alright, I'm having trouble finding a formula to answer this problem.
a 58N weight is being suspended by 2 cables. the cable on the left side is horizontal, while the other cable is at a 60' angle.
What is the tension of the right side cable? (T1)
What is the tension of the left side cable, the horizontal one? (T2)
I started off by trying to find the sum of all the forces, but I'm already stuck.
I have;
{Fx = T2 - T1cos60 = 0
and
{Fy = T1sin60 - 58N = 0
is this right so far, or do i have the cos and the sin switched?
That depends on whether the 60° is with respect to horizontal or vertical.
If the angle is with respect to the horizontal, then your equations are correct.
http://img123.imageshack.us/img123/2411/118dj.th.png
that's the problem.
i've done this;
and
then to find T2 i thought i could do this;
T1sin60 = 58N
to
T1=(sin^-1)60 + 58N
but the answer is apparently wrong... so i must not have done it right.
T1sin60 = 58N is correct.
T1=(sin^-1)60 + 58N is not correct.
T1 * sin 60° = 58N => T1 = 58N / (sin 60°)
Try T2 = T1 * cos 60°
ahhh i totally forgot i could just divide both sides by it
insted i was doing something else i learned recently... damnit so many formulas! lol
thank you a lot.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
