Solve Tension in Three Blocks of Mass: m1, m2, m3
  • Thread starter Thread starter Northstar
    Rope Tension
The discussion revolves around calculating the tensions T1 and T3 in a system of three blocks connected by strings over pulleys. The user initially struggles with applying the net force equation correctly, specifically in determining the forces acting on block m1 and m3. After receiving advice to create a Free Body Diagram, the user realizes the mistake in their calculations for T1, correcting the equation to T = m(g + a). This adjustment leads to the correct determination of T1 and T3, with T3 calculated as 8(9.81 - 2.31). The thread highlights the importance of accurately setting up equations and visualizing forces in physics problems.
Northstar
I have a couple questions that I can't figure out regarding the following question. The picture pertains to the question.
http://img81.imageshack.us/img81/8229/physnd4.jpg
Three blocks of mass m1 = 4 kg, m2 = 5 kg and m3 = 8 kg are connected by strings which pass over two ideal pulleys as shown in the figure below.
What is T1, the magnitude of the tension in the string that is connected to the block of mass m1?
and
What is T3, the magnitude of the tension in the string that is connected to the block of mass m3?
I found acceleration to be 2.31m/s^2 (and it was correct). I know Fnet = ma, but for whatever reason I am setting something up wrong for Fnet. I thought Fnet would be the force of gravity acting on the block + the force being pulled up (in the case of m1) or the block going downward (as in m3).
Any help would be appreciated.
Try making a Free Body Diagram for the block in the middle. That will really help.
Ok, I figured it out, thanks. Basically for T1 what I was doing wrong in the equation T = m (g-a) was taking 9.81-2.31 instead of adding them together. Then I was able to figure out that T3 was 8 (9.81-2.31).
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
