Richard Feynman: http://nobelprize.org/nobel_prizes/physics/laureates/1965/feynman-lecture.html"
Well, it seemed to me quite evident that the idea that a particle acts on itself, that the electrical force acts on the same particle that generates it, is not a necessary one - it is a sort of a silly one, as a matter of fact. And, so I suggested to myself, that electrons cannot act on themselves, they can only act on other electrons. That means there is no field at all. You see, if all charges contribute to making a single common field, and if that common field acts back on all the charges, then each charge must act back on itself. Well, that was where the mistake was, there was no field. It was just that when you shook one charge, another would shake later. There was a direct interaction between charges, albeit with a delay. The law of force connecting the motion of one charge with another would just involve a delay. Shake this one, that one shakes later. The sun atom shakes; my eye electron shakes eight minutes later, because of a direct interaction across.
Now, this has the attractive feature that it solves both problems at once. First, I can say immediately, I don't let the electron act on itself, I just let this act on that, hence, no self-energy! Secondly, there is not an infinite number of degrees of freedom in the field. There is no field at all; or if you insist on thinking in terms of ideas like that of a field, this field is always completely determined by the action of the particles which produce it. You shake this particle, it shakes that one, but if you want to think in a field way, the field, if it's there, would be entirely determined by the matter which generates it, and therefore, the field does not have any independent degrees of freedom and the infinities from the degrees of freedom would then be removed. As a matter of fact, when we look out anywhere and see light, we can always "see" some matter as the source of the light.
