Calculating Acceleration: Solving for the Force of a Clam
  • Thread starter Thread starter Phoenixtears
    Forces
The discussion focuses on calculating the acceleration of a clam that pushes water to move. A 0.5 kg clam accelerates 0.6 kg of water to 1.9 m/s in 0.43 seconds, but the initial calculations were incorrect. The correct method involves applying conservation of momentum and recognizing that the clam's acceleration should be calculated separately from the water's. The final acceleration of the clam is determined to be 5.3 m/s². The participant acknowledges the misunderstanding and appreciates the clarification on using the correct variables.
Phoenixtears
SOLVED
Sea clams move by pushing water in one direction so that the water pushes them in the opposite direction. In doing so a 0.5 kg clam can accelerate 0.6 kg of water from rest to a speed of 1.9 m/s in 0.43 seconds. Calculate the magnitude of the clam's acceleration
F= ma
Vf^2= V0^2 + 2ax
Vf= V0 + at
x= V0*t + .5a(t^2)
I'm not sure why my answer isn't checking out. The initial velocity is 0. The final velocity is 1.9. The time is .43. These all fit into the third equation: 1.9= 0 + .43a. a then equals 4.42. This, however, is not working as my answer. What am I missing?
Thanks in advance!
~Phoenix
F= ma
Vf^2= V0^2 + 2ax
Vf= V0 + at
x= V0*t + .5a(t^2)
Thanks in advance!
~Phoenix
Apply conservation of momentum
0.6*1.9=0.5*v
v=2.28
a=\frac{\Delta v}{\Delta t}
a=2.28/0.43
a=5.3
Does this help u?
The clam accelerates the water from 0 to 1.9 m/s in 0.43s. You need to calculate the acceleration of the clam, not the water. (hint: remember Newton's third law)
OH! Alrighty, gotcha. That makes sense to me. Thank you so much. I realize now that I was mixing variables that shouldn't be used to solve for this.
Thank you so very much!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
