The definition of a field supposes simultaneity?
A field is characterized as a distribution across space, implying a specific moment in time, which raises questions about the concept of simultaneity. While simultaneity is often considered frame-relative in special relativity, it is not entirely meaningless. The discussion highlights that static fields may render simultaneity irrelevant, whereas dynamic fields require a four-dimensional spacetime description. This indicates that fields in physics are better understood within the context of spacetime rather than just three-dimensional space. Ultimately, the relationship between fields and simultaneity is complex and necessitates a nuanced understanding of relativity.
nomadreid
A field is defined as a distribution throughout all space (or at least a portion of it). But all of (a portion of) space means all of space at a particular moment, no? But that sounds as if it assumes simultaneity. But I thought simultaneity was a meaningless concept, according to relativity. What am I missing here?
If a field is static then simultaneity is irrelevant. If a field is changing then one may need to describe it as a field over four dimensional space-time rather than just three-dimensional space.
Simultaneity is not meaningless in special relativity. It is just that it is frame-relative rather than a universal invariant.
Likes nomadreid
In field theory the fields are fields on spacetime, not just space.
Likes nomadreid
Thank you, jbriggs444 and DaleSpam. Your responses were very helpful.
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
