Transforming a Differential Equation: Tips and Tricks
  • Thread starter Thread starter discoverer02
    Algebra
To transform the general solution of the differential equation into the desired form, the equation can be manipulated into a quadratic format. By rewriting the original equation as a quadratic in y, specifically x^2y^2 - Cy - x^3 = 0, the quadratic formula can be applied. This approach will yield the necessary transformation to the required format. The discussion highlights the importance of recognizing the quadratic nature of the equation for effective solving. Ultimately, applying the quadratic formula is the key step to achieve the desired solution.
discoverer02
I need to put this general solution to a differential in the following form:
My solution is in the form (-x^3)(y^(-1)) + (x^2)y = C
It needs to be in the form y = (x^(-2))[c+-((c^2) + x^5)^(1/2)]
I've been noodling around with it for a while and it's not working out for me. Does anyone something I can factor out or multiply by that will put it into a friendlier form?
Thanks.
You've got:
\frac{-x^3}{y}+x^2y=C
-x^3=Cy-x^2y^2
Which is a quadratic equation in y.
x^2y^2-Cy-x^3=0
Apply the quadratic formula, and you should get there.
Multiply through by y and you have a quadratic equation in the y variable.
cookiemonster
Thanks.
I should have seen this. It's a no brainer. Where was my brain last night?[zz)]
