The figure represents a system composed of pulleys
The problem involves a system of two ideal fixed pulleys supporting three masses A, B, and C, all of equal mass M, connected by light and inextensible threads. The original poster is trying to determine the acceleration of mass A, which is influenced by the connections to masses B and C.
  • Participants discuss the need to create free body diagrams (FBDs) for each mass to analyze the forces and accelerations involved. There are questions about whether the acceleration is the same for all masses and how to express the relationships between the forces acting on them.
Some participants have provided guidance on the importance of showing efforts through diagrams and equations. There is an ongoing exploration of the relationships between the masses and the forces acting on them, with no clear consensus yet on the acceleration values.
Participants have noted the requirement to show work before receiving further help, and there is mention of a missing figure that is crucial for understanding the problem setup.
leticia beira
homework Helper
The figure represents a system composed of two ideal fixed pulleys that support three masses A, B, and C of the same mass M, suspended by light and inextensible threads. Massor A is simultaneously suspended by two wires, one connected to massor B (wire 1) and the other to massor C (wire 2). We can say that the acceleration of massor A will be:
( ) 10/3 m / s² down
( ) 10/3 m / s² upwards
( ) 20/3 m / s² down
( ) 20/3 m / s² upwardshow do i calculate step by step?
Summary:: the figure represents a system composed of two pulleys, can we say that the acceleration of massor A will be?
A figura representa um sistema composto por duas polias fixas ideais que suportam três massas A, B e C da mesma massa M, suspensas por fios leves e inextensíveis. O massor A é suspenso simultaneamente por dois fios, um conectado ao massor B (fio 1) e outro ao massor C (fio 2). Podemos dizer que a aceleração do massor A será?
Socorro
leticia beira said:
Homework Statement:: homework Helper
Relevant Equations:: --
Welcome to the PF. :smile:
Your attachment did not seem to work. Maybe try again? Use the "Attach files" link below the Edit window to add a PDF or JPEG image of the problem.
Also, you are required to show your efforts to start working the problem before we can offer tutorial help. Please show us your Free Body Diagram(s) and show us how you are trying to work this problem. Thank you.
What figure?
Socorro
Yay, you finally got a figure to post. Now show us your Free Body Diagram (FBD) for this system and tell us what you think the answer is.
By creating variables to represent the accelerations and tensions and writing equations that relate the acceleration of each object to the forces that act on it.
Also, you need to consider the question, which must be asked when two or more pulleys are present, "is the acceleration the same for all the masses? If the answer is "yes", you need to explain why you think so; if the answer is "no", you need to find how the accelerations differ from each other.
For this question you need to create 3 free body diagrams (FBDs), also called force diagrams, one for each mass. Put in all the forces acting on that particular mass. That is @berkeman's suggestion. Once you have done this, write Newton's second law that is appropriate to each FBD. That is @haruspex's suggestion.
  • · Replies 22 ·
  • · Replies 23 ·
  • · Replies 40 ·
  • · Replies 22 ·
  • · Replies 18 ·
