The periodic time of an elastic string's oscillation
The discussion centers on deriving the periodic time of an elastic string's oscillation. The initial calculations involve tension, force, and displacement, but the approach is questioned regarding the validity of expressions for force and acceleration. Participants emphasize the importance of ensuring that the differential equation accounts for all values of displacement and the potential for the string to become slack, which affects the forces acting on the mass. There is confusion over dimensional correctness in the derived equations, particularly when adding terms of different dimensions. The conversation highlights the need for a clearer understanding of the dynamics involved when the string is slack and how it influences the overall motion of the mass.
patric44
a string with length "a" attached to a point and has a mass "m " attached to it , the elasticity of the string λ = the weight of that mass . if the mass is pulled downwards such that the string length becomes 4 times it original length . and its left to oscillate .
prove that mass will return back to that point of pulling for the first time after a time = √ (a/g)*(2√ 3 + 4π/3 )
prove that t = √ (a/g)*(2√ 3 + 4π/3 )
λ =mg
i guess he is asking for the periodic time :
$$Tension = \frac {λ*y}{a} $$
\lambda= mg
$$y =3a$$
$$T = 3mg$$
$$F = T-mg\Longrightarrow F = 3mg-mg = 2mg$$
$$m{y}''=2mg$$
$$y'' = 2g \therefore\frac { dy'}{dt} = 2g \Longrightarrow y' = 2gt+c1$$ by applying the boundary conditions and integrating
$$y = gt^2 -3a $$
$$ t^2=\frac{y-3a}{g}⇒ t =√(\frac{a}{g})√(\frac{y}{a} +3) $$
i am stuck here what should i do next
is this the right approach to solve it ?
i will appreciate any help
thanks
patric44 said:
$$T = 3mg$$
This is true only at the instant where ##y=3a##.
$$m{y}''=2mg$$
This is true only when ##y = 3a##.
You will need expressions for ##F## and ##y''## that hold for any positive value of ##y##. Does ##y## ever go negative?
So I should work this with y as a variable, bud this led me to some very lengthy calculations :
I won't be able to easily quote particular parts of your work since it is posted as a picture.
Be careful with signs. Your diagram shows that you are taking positive ##y## downward. That's fine. But then, the weight of the mass ##mg## would be a positive force while the tension would be negative. So, your signs don't look right when you wrote ##F = T - mg##.
For a mass hanging on a spring or elastic string, it is often a good idea to introduce a variable that measures the displacement of the mass from the equilibrium position (where the mass would hang at rest). You should find that you get a familiar differential equation that will yield a familiar type of motion (as long as the string doesn't go slack).
so you are suggesting that the differential equation would be :
$$ my''=mg-\frac{λ}{a}y ⇒y''=g-\frac{g}{a}y $$
is that the right differential equation to solve ?
i tried to solve it using online calculator to save some time :
$$ y′′(t)+\frac{g}{a}y(t)=g , y(0)=3a , y′(0)=0 $$
the answer was ?! :
what am i doing wrong ?
the answer was ?! :
How else might you write eiy?
i could write this as :
after expressing this in euler's form and canceling the sin :
$$ y(t) = a+2\cos( {\sqrt{\frac{g}{a}}t}) $$
so
$$ t = \sqrt{\frac{a}{g}}\cos^{-1} ({\frac{y-a}{2}})$$
how would i get the periodic time as :
$$ t = \sqrt{\frac{a}{g}}*(2√ 3 + 4π/3 ) $$
Close. Check to see if this equation is dimensionally correct.
You need to consider the possibility that the string becomes slack.
its not clear to me how its not dimensionally correct , inst the cos term has no units and a has a unit of length
same as y ?
- what you mean by slack ? and how should it effect my approach for solving the problem ?
same as y ?
Consider ##a + 2\cos(\sqrt{\frac{g}{a}}t)##
You are adding two terms. The first term is ##a## and has the dimensions of length. The second term is ##2\cos(\sqrt{\frac{g}{a}}t)## and is dimensionless. You can't add two terms of different dimensions.
- what you mean by slack? and how should it effect my approach for solving the problem ?
Try to picture what's going on. After releasing the mass, the mass will move upward. If it moves far enough upward, the string will become "loose" ("slack"). While the string is slack, it does not exert a force on the mass.
Some things for you to consider:
(1) For what value of ##y## does the string first become slack?
(2) While the string is slack, what force or forces act on the mass?
(3) How would you describe the motion of the mass while the string is slack?
