The Power of Carbon: 4 Carbon Bonds
Carbon typically forms four bonds, but the possibility of a quadruple bond between two carbon atoms is largely theoretical. The C2 molecule is often cited as a candidate for such bonding, yet it is primarily characterized by double bonds. Recent discussions highlight that while some research suggests the existence of a carbon-carbon quadruple bond, it is considered weak and not a true bond in the traditional sense. The concept remains debated within the scientific community, with some experts acknowledging it as a theoretical possibility rather than a practical reality.
nil1996
Can carbon form four bonds with another carbon?
Chemistry news on Phys.org
The only possibility for a quadruple bond between two carbon atoms would be the C2 molecule, as no other bonding to additional atoms would be possible. And C2 is only doubly bonded:
http://chemwiki.ucdavis.edu/Wikitexts/UC_Davis/UCD_Chem_110B/Theories_of_Electronic_Molecular_Structure/Homonuclear_Diatomic_Molecules
I wouldn't consider this "long-bond" a real bond as it is also much weaker than a true bond. But as it is only a concept you are of course free to do so.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
