Engineering The voltage(V) volts in a circuit
  • Thread starter Thread starter BonBon101
    Circuit Volts
The voltage in the circuit is expressed as V(t) = 18(1 - e^(-4t/9), and the derivative dV/dt is calculated as dV/dt = 18(-4/9)(1 - e^(-4t/9)). Evaluating this at t=0 yields dV/dt = 0 mA, while at t=5 seconds, it results in dV/dt ≈ -7.13 mA. The discussion includes questions about the derivative of constant terms and the exponential function with respect to time. Overall, the participant seeks clarification on their calculations and understanding of derivatives in the context of this voltage equation.
BonBon101
The voltage(V) volts in a circuit at time(t) is given by
V(t)=18(1 - e -4t/9)
Find the expression for dV/dt.
Hence evaluate dV/dt at
(a)t=0 and (b)t=5 seconds
Just wondering if this is right and if not where did i go wrong
dV/dt=18(-4/9)(1-e-4/9t)
= -9(1-e-4/9t)
(a) t=0 -8(1-e-4/9(0))
=0mA
(b)t=5 -8(1-e-4/9(5))
=-7.13mA
\frac{d}{dt}V(t) = \frac{d}{dt}18 - \frac{d}{dt}18e^{-4t/9} what's the derivative?
not to sure.Im sorry but I am not that good at this hoping to get better!
Well
Whats the derivative of 18 with respect to t?
What about 18exp(-4t/9) with respect to t?
I separated the parts of the equation using the fact that \frac{d}{dt}[v(t) + w(t)] = \frac{d}{dt}[v(t)] + \frac{d}{dt}[w(t)] you can generally remember this rule as "the derivative of the sum is the sum of the derivatives".
Does this make sense?
