Exploring Einstein's Principle of Relativity
In summary, the conversation discusses the conflict between Einstein's theory of relativity and Newton's laws of motion. While the Galilean transformation holds true for low speeds, it is superseded by the Lorentz transformation for higher velocities, where speeds never exceed the speed of light. This is in line with Einstein's belief that nothing can travel faster than the speed of light, which is a constant speed. The concept of relativity is applied to light, suggesting that it has a mass and its velocity remains constant regardless of the observer's reference frame. The formulas of special relativity have been extensively tested at low velocities but have not been tested in space or at speeds close to the speed of light. The conversation also touches on the idea of
pinoyplaya
Hey guys. I am a college physics student and ever since this theory was introduced to me in high school, I refuse to believe it.
What caught my attention first is that Einstein's Principle of Relativity.
Einstein suggest that the laws of physics are the same for all observers in uniform motion relative to one another. However, using Galilean Transformations, two objects traveling on opposite directions, one with a velocity v while the other has a velocity 2v. Relative to each other, object one is traveling with a velocity 3v relative to object two and vice versa. Einstein does not refute this at all.
However, when applied to light, this should remain the same. No matter what the object was, bullet, car, rocket, or light, this transformation should remain the same. But Einstein disagrees. He suggest that light remains at the speed of light and is a constant speed (which I agree). But he also says (from what I learned) that nothing can have a velocity faster than the speed of light despite their reference frames.
So in other words, if the objects I talked about above were traveling at v=0.9c where c is the speed of light, then their relative velocities will never be faster than the speed of light. In this case their relative velocity is 3v = 2.7 times the speed of light.
How can Einstein be right if Galilean transformation holds true?
The Galilean transformation does not hold true. It is superseded by the Lorentz transformation. The velocity addition rules then change, and speeds never exceed the speed of light.
As nicksauce stated, the Galilean transformation do not hold true. They are a slow-speed (v=0, to be exact) approximation of the Lorentzian transformations.
Ok. Then my question is why does Galilean transformation work at low speeds such as comparison car speeds but when it comes to higher velocities it is no longer valid. I know that this can be used just as an estimate but it seems accurate.
Car A headed east at 60mph and Car B passes Car A moving at a direct opposite direction. Car B has a velocity of 50mph. Both velocities are relative to the earth/ground.
The person in Car A sees Car B moving at 110 mph and Car A sees the earth/ground moving at 60mph.
Is this correct? If so, then I still don't understand why this concept cannot be applied to light.
And if Einstein is right, suggesting that light does have mass, then wouldn't an object with a slightly less mass than light can have a velocity faster than the speed of light?
Newton suggest that light is massless, then obviously nothing travels faster than the speed of light. Einstein supports that nothing can travel faster than the speed of light, but he argues with Newton and says that light does have a mass.
Edit: I guess I'm just into the idea that if nothing travels faster than the speed of light, then the speed of light should be infinite. But of course that doesn't hold true because otherwise, the light rays from the sun would not take roughly 8 minutes to pass planet earth.
Another thing that confuses me is that if the sun were to explode, we don't experience its catastrophe 8 minutes prior to the explosion. I highly disagree. We may not be able to SEE the result 8 minutes prior but its affect on planet Earth should be instantaneous (as Newton suggest) but Einstein suggest otherwise. He is saying that light gets there first before anything else.
And if the sun disappears, our planet does not go out of orbit until around 8 minutes has passed since the event occurred. Newton says that our planet should get out of orbit immediately.
Think of it this way. You hang a ball on the ceiling supported by a string. You cut the string off, Einstein says that the ball (which is affected by gravity) does not fall immediately but instead, the string must pass the ball first before the ball starts to fall. And of course this is completely false.
Newton suggest that this ball will fall immediately as soon as the string is cut. And as expected, it is what should and does happen.
jtbell said:
Try working out a few numeric examples using the relativistic "velocity addition" formula:
http://hyperphysics.phy-astr.gsu.edu/HBASE/relativ/einvel.html
Of course it will work because these are formulas derived by Einstein himself.
If I created a formula that says 1+1=3 then it will work.
I guess the only way to show that Einstein's theory of relativity is to test it on objects with a velocity that is fractional to c. At least .5c, otherwise, its still a theory.
1) Why is the Galilean transformation a good approximation at low speeds? Well, it can be shown mathematically, but I don't know a reason intuitively why it is true.
2) Light doesn't have mass. I don't know what gives you that idea.
3) Gravitational influence also propagates at the speed of light. Therefore, we see the catastrophe and feel its impact at the same time.
The only way if this formula holds true is to actually travel close to the speed of light and test it. Better yet, test it in space.
The formulas of special relativity are extremely(!) well tested. Particle colliders rely on them daily.
Extremely tested at low velocities. Not even close to the speed of light. And the fact that it is tested on Earth and not on space.
Edit: On another topic, good luck collecting anti-matter when you have a particle accelerator surrounded by full of matter. And please, don't tell me they successfully collected any for more than 1 second.
Is this correct?
No; see jtbell's posts.
Light doesn't have rest mass, while massive particles do have rest mass, and Einstein did not suggest anything that contradicts this.
Particle accelerators routinely bring particles to within a fraction of the speed of light. To me, that is not a low velocity. If the equations of special relativity broke down, they would notice. And why does it matter if it's in Earth or in space?
No? Hahaha. Dont tell me if I am moving towards you at 2mph I am not really moving at 2mph.
E=mc^2
That's Einstein's famous equation isn't it? Anything that has energy has mass, light has energy therefore it has mass.
LOL, why does it matter if its on Earth or space. Newton's law of gravitation. Not to mention, Einstein says light has mass, his equation does not take into account gravity and light's mass.
And as for particle accelerators, they are not used to test Einstein's Theory of Relativity. LOL.
pinoyplaya said:
E=mc^2
No. This equation says that anything with rest mass has rest energy. Photons do not have rest mass. The full equation is E^2 = p^2c^2 + m^2c^4 (p is momentum), so for photons, E = pc.
If you suggest that is wrong, then you definitely have to look at special relativity one more time.
pinoyplaya said:
E=mc^2
The equation actually is
[tex]E^2 - \left( c p \right)^2 = \left( m c^2 \right)^2,[/tex]
where [itex]p[/itex] is momenum. In a frame in which a massive particle is at rest, [itex]m \neq 0[/itex] and [itex]p = 0[/itex], and the above equation becomes [itex]E = mc^2[/itex]. Photons, which are never at rest in any frame, have, in all frames, [itex]m = 0[/itex] and [itex]p \ne 0[/itex]. Consequently, for photons, the above equation becomes [itex]E = cp[/itex].
No of course they aren't use to test relativity. Because we already know from a number of other experiments that relativity is true. But if it weren't, particle accelerators would definitely notice.
And relativity (general relativity specifically) has been tested in space, and it matches experiments extremely well.
Photons do not have rest mass... yes in theory. I would like to see this experimentally tested... impossible btw.
Gravitational Influence also propagates at the speed of light -> According to Einstein.
If Einstein created new numbers and this numbers suggest 1 + 1 = 3, as we know it today it is false, but of course whoever said 2 is actually two. These are just what representations of them.
Light doesn't have mass. Well.. once again, if light has mass, then it would be very much possible to overcome the speed of light.
Well I'm done here. You clearly have some sort of agenda and aren't willing to learn.
Oh I am willing to learn. The fact that Einstein and Newton contradicts each other... who am I suppose to believe?
Just like when scientist started claiming that Pluto is no longer a planet. Even scientist can't come to a conclusion what a planet is.
Scientific theories change from day to day.
George Jones said:
pinoyplaya, did you read the rules to which you agreed when you registered for Physics Forums?
https://www.physicsforums.com/showthread.php?t=5374
It appears that you are not here to learn, you are here to push aggressively non-mainstream views.
Oh I read the rules. I am not here to create an argument. I am here to find answers to why two famous physicist have a clash in views.
You have a very faulty understanding of Special Relativity.
As for light having mass using your "E=mc^2" misunderstanding, read our FAQ in the General Physics section.
Particle accelerators MAKE USE of relativistic equations. Considering that many of them approach 0.99c or more, it is silly for you to suggest that they don't approach anywhere near relativistic speed. Furthermore, we do a lot of relativistic correction in the band structure of the very semiconductor that you are using. If not, we get experiments that do not match the theoretical description!
If you don't "believe" in Relativity, I strongly suggest you do not fly anymore, considering that all the GPS's and the satellites make use of both SR and GR.
There are tons of experimental verification of SR and GR. On the other hand, you have presented none. All you have done is argue against it based on a very faulty understanding of it. We can't debunk something when it is based on a non-existent understanding.
Zz.
They don't! If you simplify All of SR's equation to v<<c, you DERIVE Newton's laws! Newton's laws is a simplification of Einstein's SR!
Zz.
You could have fooled me. When you START out here with statement like this:
... it shows that you've already made up your mind. It is made worst when you have a faulty understanding of what you refused to believe.
Zz.
Einstein theories have larger domains of validity than Newton's theories. Everything that Newton's theories predict, and that is observed, is also predicted by Einstein's theories (in some appropriate limit), but Einstein's theories predict things that have been observed, and that aren't predicted by Newton's theories (in any limit).
You asked the question of why the Galilean transformation works at low speed. The answer can be found by trying some examples using both and seeing that at low speed the deviation between the two is very small. That's why this was suggested to you - it wasn't suggested that that was a proof that the Lorentz transformation is correct.
It is very difficult to learn when you approach learning with such a closed mind.
[edit: sorry, didn't see that the thread was locked.]
Related to Exploring Einstein's Principle of Relativity
1. What is Einstein's Principle of Relativity?
Einstein's Principle of Relativity is a fundamental concept in physics that states that the laws of physics are the same for all observers in uniform motion, regardless of their relative velocities.
2. How did Einstein come up with the Principle of Relativity?
Einstein developed the Principle of Relativity in 1905 as part of his theory of special relativity, which was based on his experiments and observations of the speed of light and the behavior of moving objects.
3. What is the difference between special and general relativity?
Special relativity deals with the laws of physics in uniform motion, while general relativity extends these laws to include non-uniform motion and the effects of gravity.
4. How has the Principle of Relativity been tested and verified?
The Principle of Relativity has been extensively tested and verified through various experiments, including the Michelson-Morley experiment and the Hafele-Keating experiment. Additionally, its predictions have been consistently confirmed through observations and technological advancements.
5. How has the Principle of Relativity impacted our understanding of the universe?
The Principle of Relativity has significantly impacted our understanding of the universe by revolutionizing our understanding of space, time, and gravity. It has also led to the development of groundbreaking technologies such as GPS and nuclear energy.
