Thermal Energy created by block sliding down ramp
A 1300 N crate sliding down a 15 m ramp at a 40-degree angle raises questions about calculating thermal energy without a given coefficient of friction. The discussion highlights that achieving constant velocity requires zero net acceleration, which can be calculated using gravitational acceleration. The acceleration down the ramp is determined to be approximately 6.3 m/s², necessitating equal frictional force to maintain constant velocity. By calculating the mass of the crate and applying the distance, the thermal energy generated is estimated at about 12,534 J. The conversation also questions the assumption of constant velocity in the problem.
ccflyfisher
1. A 1300 N crate slides 15 m down a ramp that makes an angle of 40 degrees with the horizontal.
2. F therm = Fk\DeltaX
3. I understand how to solve this with the coefficient of friction given, but how can I without the problem stating \mu?
Without more information, you can't.
You can solve this because to get a constant velocity down the ramp, there must be 0 net acceleration. You can solve for the acceleration down the ramp due to gravity but doing gsin(\theta),or 9.8m/s2*sin(40\circ), which gives you 6.3m/s2. Since this is the acceleration downwards, friction must produce the same acceleration up the ramp to produce the constant velocity. Simply multiply this acceleration by the mass of the object (1300N/9.8m/s2=132.653), then by 15 meters.
You get about 12534.358 J, or 1.3*104.
Who said anything about the crate moving at constant velocity?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
