Thermal Expansion of a steel plate
To determine the temperature increase needed for a steel plate with a circular hole to accommodate a Pyrex marble, the thermal expansion formula ∆L = alpha L(0) ∆T is applied. The diameter of the hole is 1.000 cm, while the marble has a diameter of 1.003 cm, requiring a difference of 0.00003 m in expansion. The calculations show that the steel plate must expand by this amount, leading to the conclusion that a temperature increase of approximately 350 degrees is necessary. The confusion arises from understanding that ∆T represents the change in temperature, which remains consistent regardless of the starting temperature. Ultimately, the derived temperature change aligns with the book's answer of 350 degrees.
Brit412
A steel plate has a circular hole with a diameter of 1.000 cm. In order to drop a Pyrex glass marble 1.003 cm in diameter through the hole in the plate, how much must the temperature of the system be raised? (Assume the plate and the marble always have the same temperature)
∆L= alpha L(0) ∆T
Use the above equation for both the marble and plate, but I don't know what temperature to use for ∆T
it doesn't matter what temperature it starts at, DELTA T is just the change in temperature, so if it went from 0 to 10 or 900 to 910 DELTA T would still be 10.
I'm still confused. The book says the answer is 350 but I don't see how they arrived at that answer. Here's what I did so far:
∆L (plate) = (12E-6) times (0.01m)
∆L (marble) = (3.3E-6) times (0.01003m)
so, the difference in length between the P and the M is .00003m.
so what youre looking for will be the temperature at which the ∆Lp is different by ∆m by .00003m. (since when the plate is .00003 meters bigger, the marble will fit through.)
so ∆Lp-.00003m = ∆m
(it is minus the difference because you really want the plate to be .00003m bigger, so if you substract it, it would make the terms equal
then you can plug in for the rest
(∆T(12E-6)(.01))-.0003=∆T(3.3E-6)(.01003)
and factor out the T, and it will leave you with ∆T=345.2
Thank you so much for helping me understand that problem
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
