Thermistor's temperature problem
  • Thread starter Thread starter matt_crouch
    Temperature
The discussion centers on solving for the constants R0 and B in the thermistor equation R=R0e^(B/T) using given resistance values at the ice and steam points. The user attempts to manipulate the equation by taking logarithms but questions whether their rearrangement is correct. They express confusion about how to handle the constants in simultaneous equations derived from the logarithmic form. Clarification is sought on the proper formulation of the logarithmic equation. The conversation highlights the importance of accurately applying logarithmic properties in thermistor calculations.
matt_crouch
A thermistor's temperature dependence is given by R=R0eb/t
where R is in ohms T is in Kelvins R0 and B are constants to be found.
a) If R =7360 at the ice point and 153 at steam point find R0 and B
I took logs so
LnR=R0B/T
rearranged so
(LnR)T/B=R0
then get simultaneous equations but the constant i am trying to find so for this example B are just going to cancel?
(Ln153)x373.15/B = (Ln7360)x273.15/B
Thanks in advance
I took logs so
LnR=R0B/T
Shouldn't that be LnR=LnR0 + B/T ?
  • · Replies 18 ·
  • · Replies 33 ·
