Thermo: Change in temp effect on volume of a steel container
The discussion revolves around calculating the volume change of a steel container filled with carbon tetrachloride due to temperature increase. The average coefficient of volume expansion for carbon tetrachloride is given as 5.81 x 10^-4 (°C)^-1. The user initially attempted to apply the volume expansion formula but arrived at an incorrect result of 0.484 gallons, which was close to the correct answer. Ultimately, the user resolved the issue independently and expressed gratitude for any potential assistance. The conversation highlights the importance of correctly applying thermal expansion principles in practical scenarios.
PhysLiz
The average coefficient of volume expansion for carbon tetrachloride is 5.81*10-4 (°C)-1. If a 49.0 gal steel container is filled completely with carbon tetrachloride when the temperature is 10.0°C, how much will spill over when the temperature rises to 27.0°C?
ΔL = α*(original length)*ΔT
I used this equation except instead of units of length, I substituted units of volume. So my final equation was:
ΔL = (5.81E-4 (°C)-1) * (49.0 gal) * (27°C - 10°C) = 0.484 gallons. This is incorrect, but within 10% of the correct answer. Not sure what I am doing wrong. Any help is greatly appreciated, Thank you!
I have solved it - thanks anyway!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
