Thermodynamics - heat flow of a rubber band
mooshasta
Consider a rubber band for which the tension, f, as a function of temperature T and length L is f = \kappa T (L+\gamma L^2), where \kappa and \gamma are positive constants. Determine the heat flow between it and its surroundings when the rubber band is stretched reversibly and isothermically from length L_1 to length L_2.
dE = TdS + fdL + \mu dN
I think the question is asking to find \left( \frac{\partial E}{\partial L} \right)_{T,N} and integrate that. I'm not sure how to get this quantity, though, since I don't know what entropy is. Can I use the Helmholtz free energy when calculating heat transfer? I don't think so, since they are not equal...
Thank you for your help!
It's not \left(\frac{\partial E}{\partial L}\right)_{T,N}, since some of the energy change dE comes from strain energy, and you wouldn't include that in the heat flow. So you only want to integrate part of dE; which part is it? (Take a look at your equation.)
(Then I expect you'll get into the fun world of Maxwell relations.)
As I understand it, then, the heat flow should be \int TdS, since this is the heat part of the equation. So then should I be integrating:
T\int^{L_2}_{L_1} \left( \frac{\partial S}{\partial L}} \right)_{T,N} dL
Using a Maxwell relation as you said, I see that -\left( \frac{\partial S}{\partial L} \right)_{N,T} = \left( \frac{\partial f}{\partial T} \right)_{N,L}, and then the integral is straightforward.
I am just unsure if that integral above is correct, and if it is, what is the basis on getting that from \int TdS in this context.
Thanks! I appreciate your help.
Looks good to me!
I still am a little confused how to get to that integral. If S is a function of E, L, and N, doesn't that mean then that:
\left( dS \right)_{T,N} = \left( \frac{\partial S}{\partial E} \right)_{L,N} dE + \left( \frac{\partial S}{\partial L} \right)_{E,N} dL
But instead I wrote \left( \frac{\partial S}{\partial L} \right)_{T,N} dL. How does this match with the above equation?
Thanks again. I'm probably missing something pretty fundamental :)
Let's drop N, since it's constant here. S is a function of two independent variables. We could write
dS=\left(\frac{\partial S}{\partial E}\right)_LdE+\left(\frac{\partial S}{\partial L}\right)_EdL
or
dS=\left(\frac{\partial S}{\partial T}\right)_LdT+\left(\frac{\partial S}{\partial L}\right)_TdL
The first isn't of much use; the second simplifies into the integrand above. Does this make sense?
I think I get it now, thank you. I didn't realize that one of the independent variables could be the conjugate (T).
Thanks!
