Thermodynamics - heat, internal energy, work
Heat flows into an ideal gas at constant volume, causing pressure to rise from 1.5 atm to 5.5 atm. During compression at constant pressure from 5.0 L to 2.5 L, the gas returns to its original temperature. No work is done in the first process, while the work done during compression is calculated as 1390J after correcting a typo in the volume. The change in internal energy is zero due to no net temperature change, and 1390J of heat exits the system. The calculations and reasoning presented are confirmed as accurate.
Ampere
Heat flows into an ideal gas at a constant volume. The pressure increases from 1.5 atm to 5.5 atm. Next the gas is compressed at constant pressure from 5.0 L to 2.5 L and goes back to its original temperature.
1.What is the total work done on the gas in the process?
2.What is the total change in internal energy?
3.What is the total heat flow of the process?
U = Q + W
W = -P*ΔV
1. No work is done in the first process because the volume is constant. The work done on the gas in the second process is W = -(5.5 atm) * (2.5 L - 5.5 L) = 1390J
2. The change in internal energy is 0 because there is no net change in temperature.
3. 1390J of heat must have left the system because U = Q + W.
Is this right?
Hello, Ampere.
Your process looks right, but I don't agree with your conversion from L-atm to Joules.
[EDIT: It's not the conversion, it's a typo in your equation W = -(5.5 atm) * (2.5 L - 5.5 L) = 1390J
where you wrote 5.5 L instead of 5.0 L.
I agree with your answer now.]
Yes, I meant (2.5 L - 5.0 L). Thanks for the confirmation!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
