Thermodynamics in a refridgerator
  • Thread starter Thread starter Saxby
    Thermodynamics
A refrigerator operating in a Carnot cycle abstracts 1.0 * 10^6 J of heat from water at 273 K and releases heat to a room at 300 K. To find the heat given out to the room, the work done by the refrigerator, and the coefficient of performance, the relationship W = Qh - Qc is essential, where Qc is the heat removed and Qh is the heat released. The coefficient of performance can be calculated using the temperatures of the cold and hot reservoirs. The specific heat capacities are not necessary for these calculations, as the focus is on the heat transfer and the Carnot efficiency. Understanding these principles allows for accurate calculations of the refrigerator's performance.
Saxby
A refrigerator operating in a Carnot cycle is used to create 273 K by abstracting heat from water at 273 K and giving out heat to a room at 300K. To produce 3 kg of ice it abstracts 1.0 * 106J of heat from the water.
Calculate:
(i) The amount of heat given out to the room;
(ii) The amount of work supplied by the refrigerator;
(iii) The coefficient of performance of the refrigerator.
Q = m*c*ΔT
W = Q = Qc - Qh
e = Qc / (Qh - Qc)
Qc = Heat in cold reservoir
Qh = Heat in hot reservoir
I find the phrasing of this questions quite strange, what does it mean by 'used to create 273K' and is 300K just the temperature of the room? I suppose the heat given out would be 1.0 * 106J + W but i do i find W? (Just to point out we're not given the specific heat capacity of water or air)
The cold side is at 273K, and the hot side (room) is at 300K.
I think you have to assume a perfect Carnot engine here - this allows to calculate the (minimal) W required. You do not need any specific heat capacity.
Calculate:
Q = m*c*ΔT
You do not need to know the specific heat of water, as mfb pointed out. You just need to know how much heat is removed and the fact that it is a Carnot cycle.
W = Q = Qc - Qh
e = Qc / (Qh - Qc)
You have provided the expression for the COP (which you refer to as e) but you have to relate this to temperatures. (hint: what is the COP for a Carnot refrigerator operating between these temperatures?)
Your expression for W is not quite right. W = |Qh|-|Qc|, where W is the work done ON the system. You can express W in terms of Qc and COP.
W is determined from the COP and Qc. You can determine Qh from that as well.
AM
