Thermodynamics mass and energy analysis Problem
The discussion focuses on a balloon problem where the volume increases linearly with pressure, as indicated by the equation P2/P1 = V2/V1. Participants clarify that this relationship suggests a linear correlation, typically represented by the equation P = kV, where k is a constant. When manipulating the equation, the constant k cancels out, reinforcing the linear relationship between pressure and volume. This understanding is crucial for solving thermodynamics problems involving gas behavior. The explanation highlights the importance of recognizing underlying proportional relationships in thermodynamic equations.
boyongo
Im doing a balloon problem. The problem states that the volume increases linearly with pressure in the solution manual they that P2/P1=V2/V1 i think that is related linearly but i can't figure how. Can some explain?
When you write an equation like
\frac{V2}{V1} = \frac{P2}{P1}
It's usually because there's a linear relationship like
P = k V
that underlies it, where k is some constant of proportionality. When you "stack" the equation, the proportionality constant drops out:
\frac{\rlap{\backslash} k V2}{\rlap{\backslash} k V1} = \frac{P2}{P1}
thank you very much :)
